- To:
- Subject: Re: [cgal-discuss] dD Spatial Searching, sort points.
- Date: Mon, 01 Oct 2012 17:13:04 +0200
On 10/01/2012 04:55 PM, Артур Юнусо wrote:
The last function argument doesn't allow to change *the way* how pointsIn your setting, k is large since and you don't want to copy and sort the points, right?
The current API does not allow to sort in-place the points.
If you want to hack CGAL to give it a try, make the variable "queue"
of class K_neighbor_search public in file internal/K_neighbor_search.h.
Then in file internal/bounded_priority_queue.h, add a sort method
taking a comparator as argument.
Sebastien.
are sorted.
01.10.2012 18:30, Sebastien Loriot (GeometryFactory) пишет:
On 09/20/2012 10:53 AM, aptypr wrote:
In the example for k neighbor searching I found thatAs documented in [1], the last function argument control whether the
CGAL::Orthogonal_k_neighbor_search return points, sorted by distance of
initial point, are there ways to sort point in process of searching?
I want
to sort points by x, and if x are the same, by y. Right now I search k
neighbors, and sort them, which is expensive.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/dD-Spatial-Searching-sort-points-tp4655879.html
sequence of points need to be sorted.
Sebastien.
[1]
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching_ref/Class_Orthogonal_k_neighbor_search.html
- Re: [cgal-discuss] dD Spatial Searching, sort points., Sebastien Loriot (GeometryFactory), 10/01/2012
- Re: [cgal-discuss] dD Spatial Searching, sort points., Артур Юнусо, 10/01/2012
