cgal-discuss - Re: [cgal-discuss] -frounding-math option
  • To:
  • Subject: Re: [cgal-discuss] -frounding-math option
  • Date: Tue, 02 Oct 2012 11:42:15 +0200
Hi Amir,
the log provided and the error reported are not consistent.
The cmake log indicates NDEBUG is defined and assertions are deactivated in that case.
Did you set CGAL_DIR to the path of your build?
Sebastien.
On 10/02/2012 11:31 AM, Amir Vaxman wrote:
Hello,
I have recently converted my religion from Windows to Linux Mint, and
am trying to use CGAL copiled by g++ 4.6. I have configured cmake
using:
amir@amir-office ~/workspace/CGAL-4.0.2 $ cmake -fp-model strict .
-- Build CGAL from release in directory CGAL-4.0.2
-- Packagenames: CGAL-4.0.2
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=0
-- CGAL_BUGFIX_VERSION=2
-- CGAL_SONAME_VERSION=9
-- CGAL_SOVERSION =9.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- USING CMake version: 2.8.9
-- System: Linux
-- USING GCC_VERSION = '4.6.3'
-- Using gcc version 4 or later. Adding -frounding-math
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
-- GMP include: /usr/local/include
-- GMP libraries: /usr/local/lib/libgmp.so
-- GMP definitions:
-- USING GMP_VERSION = '5.0.5'
-- MPFR include: /usr/local/include
-- MPFR libraries: /usr/local/lib/libmpfr.so
-- MPFR definitions:
-- USING MPFR_VERSION = '3.1.1'
-- Boost include: /usr/local/include
-- Boost libraries: /usr/local/lib/libboost_thread.so
-- Boost definitions:
-- USING BOOST_VERSION = '1.51.0'
-- Library config detected: Qt3
-- CGAL_Qt3 needs Qt3, cannot be configured.
-- Library config detected: Qt4
-- USING QT4_VERSION = '4.8.1'
-- OpenGL include: /usr/include
-- OpenGL libraries:
/usr/lib/x86_64-linux-gnu/libGLU.so;/usr/lib/x86_64-linux-gnu/libGL.so;/usr/lib/x86_64-linux-gnu/libSM.so;/usr/lib/x86_64-linux-gnu/libICE.so;/usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
-- OpenGL definitions:
-- Qt4 include: /usr/include/qt4
-- Qt4 libraries:
/usr/lib/x86_64-linux-gnu/libQtOpenGL.so;/usr/lib/x86_64-linux-gnu/libQtGui.so;/usr/lib/x86_64-linux-gnu/libQtCore.so
-- Qt4 definitions:
-- moc executable: /usr/bin/moc-qt4
-- uic executable: /usr/bin/uic-qt4
-- Library config detected: ImageIO
-- Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
-- NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That
feature will not be activated.
-- Library config detected: Core
-- Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
-- Configuring done
-- Generating done
-- Build files have been written to: /home/amir/workspace/CGAL-4.0.2
the building went ok, but I get the following assertion when running:
CGAL_assertion_msg(-CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1),
"Wrong rounding: did you forget the
-frounding-math option if you use GCC (or -fp-model strict for
Intel)?");
It seems as if this option was added, so what is the problem?
Thanks,
Amir.
