cgal-discuss - Re: [cgal-discuss] -frounding-math option
  • To:
  • Subject: Re: [cgal-discuss] -frounding-math option
  • Date: Tue, 2 Oct 2012 12:23:28 +0200
I didn't set anything other than unpacking sources, "cmake .", "make"
and then "make install". Should I do these other stuff? I am not quite
sure.
Amir.
On Tue, Oct 2, 2012 at 11:42 AM, Sebastien Loriot (GeometryFactory)
wrote:
> Hi Amir,
> the log provided and the error reported are not consistent.
> The cmake log indicates NDEBUG is defined and assertions are deactivated in
> that case.
> Did you set CGAL_DIR to the path of your build?
> Sebastien.
> On 10/02/2012 11:31 AM, Amir Vaxman wrote:
>> Hello,
>> I have recently converted my religion from Windows to Linux Mint, and
>> am trying to use CGAL copiled by g++ 4.6. I have configured cmake
>> using:
>> amir@amir-office ~/workspace/CGAL-4.0.2 $ cmake -fp-model strict .
>> -- Build CGAL from release in directory CGAL-4.0.2
>> -- Packagenames: CGAL-4.0.2
>> -- CGAL_MAJOR_VERSION=4
>> -- CGAL_MINOR_VERSION=0
>> -- CGAL_BUGFIX_VERSION=2
>> -- CGAL_SONAME_VERSION=9
>> -- CGAL_SOVERSION =9.0.0
>> -- CGAL_REFERENCE_CACHE_DIR=
>> -- Building shared libraries
>> -- Targetting Unix Makefiles
>> -- Using /usr/bin/c++ compiler.
>> -- USING CMake version: 2.8.9
>> -- System: Linux
>> -- USING GCC_VERSION = '4.6.3'
>> -- Using gcc version 4 or later. Adding -frounding-math
>> -- Build type: Release
>> -- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
>> -- USING LDFLAGS = ' '
>> -- GMP include: /usr/local/include
>> -- GMP libraries: /usr/local/lib/libgmp.so
>> -- GMP definitions:
>> -- USING GMP_VERSION = '5.0.5'
>> -- MPFR include: /usr/local/include
>> -- MPFR libraries: /usr/local/lib/libmpfr.so
>> -- MPFR definitions:
>> -- USING MPFR_VERSION = '3.1.1'
>> -- Boost include: /usr/local/include
>> -- Boost libraries: /usr/local/lib/libboost_thread.so
>> -- Boost definitions:
>> -- USING BOOST_VERSION = '1.51.0'
>> -- Library config detected: Qt3
>> -- CGAL_Qt3 needs Qt3, cannot be configured.
>> -- Library config detected: Qt4
>> -- USING QT4_VERSION = '4.8.1'
>> -- OpenGL include: /usr/include
>> -- OpenGL libraries:
>> /usr/lib/x86_64-linux-gnu/libGLU.so;/usr/lib/x86_64-linux-gnu/libGL.so;/usr/lib/x86_64-linux-gnu/libSM.so;/usr/lib/x86_64-linux-gnu/libICE.so;/usr/lib/x86_64-linux-gnu/libX11.so;/usr/lib/x86_64-linux-gnu/libXext.so
>> -- OpenGL definitions:
>> -- Qt4 include: /usr/include/qt4
>> -- Qt4 libraries:
>> /usr/lib/x86_64-linux-gnu/libQtOpenGL.so;/usr/lib/x86_64-linux-gnu/libQtGui.so;/usr/lib/x86_64-linux-gnu/libQtCore.so
>> -- Qt4 definitions:
>> -- moc executable: /usr/bin/moc-qt4
>> -- uic executable: /usr/bin/uic-qt4
>> -- Library config detected: ImageIO
>> -- Could NOT find ZLIB (missing: ZLIB_LIBRARY ZLIB_INCLUDE_DIR)
>> -- NOTICE: CGAL_ImageIO needs ZLib to read compressed files. That
>> feature will not be activated.
>> -- Library config detected: Core
>> -- Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /home/amir/workspace/CGAL-4.0.2
>> the building went ok, but I get the following assertion when running:
>> CGAL_assertion_msg(-CGAL_IA_MUL(-1.1, 10.1) != CGAL_IA_MUL(1.1, 10.1),
>> "Wrong rounding: did you forget the
>> -frounding-math option if you use GCC (or -fp-model strict for
>> Intel)?");
>> It seems as if this option was added, so what is the problem?
>> Thanks,
>> Amir.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
