- To:
- Subject: [cgal-discuss] Re: error C2662 in creating a surface class for surface
- Date: Thu, 11 Oct 2012 09:26:08 -0700 (PDT)
Hello,
Sorry if I wasn't clear. It compiles and sometimes it works, but other time
is just hangs and there is no error message.
On the other hand when I use Exact_predicates_inexact_constructions_kernel
works more often (it never hangs), only sometimes gives me an error but by
changing some meshing parameters it ends up working.
The problem is that I need to use
Exact_predicates_exact_constructions_kernel because in my code I have a lot
of intersection computation with other AABB trees, and here it hangs a lot.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-C2662-in-creating-a-surface-class-for-surface-meshing-tp951257p4656026.html
- [cgal-discuss] Re: error C2662 in creating a surface class for surface, Jorge, 10/11/2012
- Re: [cgal-discuss] Re: error C2662 in creating a surface class for surface, Philipp Moeller, 10/11/2012
