- To:
- Subject: [cgal-discuss] Re: error C2662 in creating a surface class for surface
- Date: Thu, 11 Oct 2012 09:03:53 -0700 (PDT)
Hello,
I'm trying to do something similar. I'm trying to remesh a 3D surface using
similar code that the one given in the demo/Polyhedron/ . I'm using the
AABB_polyhedral_oracle.h.
I'm creating a triangulation as follows, also a an Object C2t3 and the AABB
tree with a pointer to an existing polyhedron (the one I want to remesh).
Tr& triangulation = * new Tr; // 3D-Surface_mesh_default_triangulation_3
C2t3& c2t3 = *(new C2t3(triangulation));
// input surface
Polyhedron* pMesh = &MyPolyhedron;
Input_RSurface input(*pMesh); // AABB tree
Then I use the function make_surface_mesh(... I'm using
Exact_predicates_exact_constructions kernel
and I have experienced the code hanging (never returning from calls to
classes that use the AABB tree).
Could you give me some insight on the issue?
thanks,
Jorge
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/error-C2662-in-creating-a-surface-class-for-surface-meshing-tp951257p4656022.html
- [cgal-discuss] Re: error C2662 in creating a surface class for surface, Jorge, 10/11/2012
- Re: [cgal-discuss] Re: error C2662 in creating a surface class for surface, Philipp Moeller, 10/11/2012
