- To:
- Subject: Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT
- Date: Mon, 22 Oct 2012 11:38:13 +0200
Le dimanche 21 octobre 2012 21:05:26 Alvin Smith a écrit :
> Hello everybody,
> I am trying to visualize a few things in CGAL. I am definitely a beginner
> to CGAL, but I've been able to turn a point cloud into a surface using the
> surface reconstruction routines. At least, I think I have, but I can't
> visualize the result, nor can I visualize the point cloud for that matter
> without resorting to using Matlab.
> I'd like to do this with QT, as geomview looks crufty and old, and maybe I
> have to show my result to a non-technical person and convince them that I
> am a serious person.
> The documentation is insufficient:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/GraphicsView/Chapter_
> main.html
That documentation requires that you have read the documentation of the Qt
Graphics View Framework:
http://doc.qt.digia.com/latest/graphicsview.html
and you should also know about Qt. The CGAL manual does not even try to be a
tutorial for making Qt demos. You should learn Qt using the Qt manual and Qt
tutorials. For examples, Qt Graphics View examples:
http://doc.qt.digia.com/latest/examples-graphicsview.html
Laurent Rineau, PhD
- [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alex Tsui, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/22/2012
- RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Philipp Moeller, 10/22/2012
- Re: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/23/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Olivier Devillers, 10/23/2012
- RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/24/2012
- Re: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/24/2012
