- To: <>
- Subject: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT
- Date: Wed, 24 Oct 2012 00:31:07 -0600
- Importance: Normal
> From:
> To:
> Date: Tue, 23 Oct 2012 09:55:02 +0200
> Subject: Re: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT
> Le lundi 22 octobre 2012 11:04:35 Alvin Smith a écrit :
> > Monsieur Rineau,
> > Thank you for taking the time to respond to my post. May I point out,
> > however, that your response is not very helpful? I have seen many posts on
> > this list that when someone has a difficult question, the automatic
> > response is, "Read the full manual," or, "This is beyond the scope of
> > CGAL."
> > No one could agree that having everyone becoming an expert in QT drawing
> > routines and writing from scratch methods for drawing CGAL objects is a
> > good use of time. "Well tough bananas!" someone might respond, "Why should
> > we support idiots who can't bother to fully understand QT?"
> > There is some truth in this, but there is also a demo (Polyhedron) packaged
> > with CGAL that actually does all of this! My point was that this demo is
> > fairly complicated, and not very useful as a tutorial. As you see, my
> > question was actually to ask if there was a simpler demo, or some other
> > method to to visualize. A better answer than the one you provided would
> > have been, "What you're looking for does not exist," or, "Go use meshlab,"
> > or even better, "Here's a demo that some guy put together awhile ago show
> > someone exactly how to do this."
> The simple truth is that CGAL has no easy tutorial about making a Qt demo
> using CGAL. There are simpler demos than demo/Polyhedron, however:
> - in 2D, for example in demo/Polygon
> - in 3D, for example in demo/AABB_tree
> I hope that it can help you.
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
demo/AABB_tree
Yes that's exactly what I am looking for! CGAL is amazing. It appears that there is a built in render function for openGL and polyhedrons. May I suggest that someone updates the QT documentation page for CGAL with a note that AABB_tree is relevant ? It may reduce the number of silly questions in the future :)
Merci pour votre temps et consideration.
-AS
> To:
> > Monsieur Rineau,
> > CGAL."
> Laurent Rineau, PhD
demo/AABB_tree
-AS
- [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alex Tsui, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/22/2012
- RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/22/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Philipp Moeller, 10/22/2012
- Re: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/23/2012
- Re: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Olivier Devillers, 10/23/2012
- RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Alvin Smith, 10/24/2012
- Re: RE: [cgal-discuss] Tutorial for visualisation in CGAL using QT, Laurent Rineau (CGAL/GeometryFactory), 10/24/2012
