- To: <>
- Subject: Re: [cgal-discuss] Problems to install CGAL-4.0.2
- Date: Mon, 22 Oct 2012 21:59:10 -0200
Thanks! Now I see that I have too many error messages, here is the Log from cmake:
(I expect that these list have no characters limitation, I'm sorry about the huge log... )
Build CGAL from release in directory CGAL-4.0.2
Packagenames: CGAL-4.0.2
CGAL_MAJOR_VERSION=4
CGAL_MINOR_VERSION=0
CGAL_BUGFIX_VERSION=2
CGAL_SONAME_VERSION=9
CGAL_SOVERSION =9.0.0
CGAL_REFERENCE_CACHE_DIR=
Building shared libraries
Targetting Unix Makefiles
Using /usr/bin/c++ compiler.
USING CMake version: 2.8.7
System: Linux
USING GCC_VERSION = '4.6.3'
Using gcc version 4 or later. Adding -frounding-math
Build type: Release
USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
USING LDFLAGS = ' '
GMPXX include: /usr/include
GMPXX libraries: /usr/lib/i386-linux-gnu/libgmpxx.so
GMP include: /usr/include
GMP libraries: /usr/lib/i386-linux-gnu/libgmp.so
GMP definitions:
USING GMP_VERSION = '5.0.2'
MPFR include: /usr/include
MPFR libraries: /usr/lib/i386-linux-gnu/libmpfr.so
MPFR definitions:
USING MPFR_VERSION = '3.1.0'
Found MPFI: /usr/lib/libmpfi.so
MPFI include: /usr/include
MPFI libraries: /usr/lib/libmpfi.so
MPFI definitions:
Could NOT find RS
CMake Error at cmake/modules/FindBoost.cmake:917 (message):
Unable to find the requested Boost libraries.
Unable to find the Boost header files. Please set BOOST_ROOT to the root
directory containing Boost or BOOST_INCLUDEDIR to the directory containing
Boost's headers.
Call Stack (most recent call first):
cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
CMakeLists.txt:496 (include)
Boost include: Boost_INCLUDE_DIR-NOTFOUND
Boost libraries:
Boost definitions:
USING BOOST_VERSION = '..'
Library config detected: Qt3
CGAL_Qt3 needs Qt3, cannot be configured.
Library config detected: ImageIO
OpenGL include: /usr/include
OpenGL libraries: /usr/lib/i386-linux-gnu/libGLU.so;/usr/lib/i386-linux-gnu/libGL.so;/usr/lib/i386-linux-gnu/libSM.so;/usr/lib/i386-linux-gnu/libICE.so;/usr/lib/i386-linux-gnu/libX11.so;/usr/lib/i386-linux-gnu/libXext.so
USING ZLIB_VERSION = '1.2.3.4'
ZLib include: /usr/include
ZLib libraries: /usr/lib/i386-linux-gnu/libz.so
Library config detected: Qt4
USING QT4_VERSION = '4.8.1'
OpenGL definitions:
Qt4 include: /usr/include/qt4
Qt4 libraries: /usr/lib/i386-linux-gnu/libQtOpenGL.so;/usr/lib/i386-linux-gnu/libQtGui.so;/usr/lib/i386-linux-gnu/libQtCore.so
Qt4 definitions:
moc executable: /usr/bin/moc-qt4
uic executable: /usr/bin/uic-qt4
Library config detected: Core
Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/AABB_tree
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_foundations
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_kernel_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Apollonius_graph_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Approximate_min_ellipsoid_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Arrangement_on_surface_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_arrangement_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_polyhedron_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_triangulation_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Boolean_set_operations_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Box_intersection_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/CGAL_ipelets
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/CGALimageIO
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circulator
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Combinatorial_map
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_decomposition_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Core
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Developers_manual
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Filtered_kernel
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Generator
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/HalfedgeDS
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Interpolation
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Interval_skip_list
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Jet_fitting_3
Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR EIGEN3_VERSION_OK) (Required is at least version "3.0.91")
A library with BLAS API not found. Please specify library location.
LAPACK requires BLAS.
NOTICE: This program requires either Eigen 3.1 (or greater) or LAPACK, and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kernel_23
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_data_structures
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_framework
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Largest_empty_rect_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Linear_cell_complex
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Matrix_search
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_3
NOTICE: This program requires Boost >= 1.34.1, and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_annulus_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_circle_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_ellipse_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_quadrilateral_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_of_spheres_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Modular_arithmetic
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_S2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Partition_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Periodic_3_triangulation_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_processing_3
NOTICE: Some of the executables in this directory need either Eigen 3.1 (or greater) or LAPACK, and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polygon
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron_IO
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial_kernel
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polytope_distance_d
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Principal_component_analysis
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Profiling_tools
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/QP_solver
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/RangeSegmentTrees
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Ridges_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/STL_Extension
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Segment_Delaunay_graph_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Skin_surface_3
NOTICE: skin_surface_pdb_reader.cpp requires ESBTL library, and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Snap_rounding_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_searching
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_sorting
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Straight_skeleton_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Stream_lines_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Subdivision_method_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_parameterization
USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG -fno-strict-aliasing'
USING EXEFLAGS = ' '
TAUCS requires LAPACK and BLAS.
NOTICE: Example Complete_parameterization_example.cpp requires Eigen 3.1 (or greater) and will not be compiled.
NOTICE: Example Taucs_parameterization.cpp requires TAUCS and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_simplification
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesher
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_reconstruction_points_3
NOTICE: Example poisson_reconstruction_example.cpp needs Eigen 3.1 (or greater) or the TAUCS library and will not be compiled.
NOTICE: Some of the executables in this directory need the TAUCS library and will not be compiled.
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_3
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Voronoi_diagram_2
Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Width_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/AABB_tree
NOTICE: This demo requires QGLViewer, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_3
NOTICE: This demo requires CGAL, the QGLViewer, OpenGL and Qt4, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Apollonius_graph_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Arrangement_on_surface_2
NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Boolean_set_operations_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Bounding_volumes
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/CGAL_ipelets
NOTICE: This program requires the Ipe include files and library, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_d
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Envelope_3
NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Generator
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Geomview
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/GraphicsView
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Interpolation
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Kinetic_data_structures
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/L1_Voronoi_diagram_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Largest_empty_rect_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Linear_cell_complex
NOTICE: This demo requires CGAL, QGLViewer, OpenGL and Qt4, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_S2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_3_triangulation_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_Lloyd_3
NOTICE: This demo requires qcollectiongenerator, QGLViewer, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polygon
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron_IO
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Principal_component_analysis
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Segment_Delaunay_graph_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Snap_rounding_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Spatial_searching_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Straight_skeleton_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Stream_lines_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_mesher
NOTICE: This demo needs libQGLViewer, and will not be compiled.
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_reconstruction_points_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_2
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3
Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3_Geomview_demos
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
Boost_INCLUDE_DIR (ADVANCED)
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/src/CGAL
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/src/CGALQt3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/src/CGALImageIO
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/src/CGALQt4
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/src/CGALCore
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/AABB_tree
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_foundations
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_kernel_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Apollonius_graph_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Approximate_min_ellipsoid_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Arrangement_on_surface_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_arrangement_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_polyhedron_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_triangulation_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Boolean_set_operations_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Box_intersection_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/CGAL_ipelets
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/CGALimageIO
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Circulator
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Combinatorial_map
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_decomposition_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Core
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Developers_manual
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Filtered_kernel
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Generator
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/HalfedgeDS
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Interpolation
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Interval_skip_list
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Jet_fitting_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Kernel_23
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_data_structures
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_framework
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Largest_empty_rect_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Linear_cell_complex
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Matrix_search
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_annulus_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_circle_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_ellipse_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_quadrilateral_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_of_spheres_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Modular_arithmetic
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_S2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Partition_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Periodic_3_triangulation_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_processing_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polygon
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron_IO
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial_kernel
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Polytope_distance_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Principal_component_analysis
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Profiling_tools
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/QP_solver
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/RangeSegmentTrees
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Ridges_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/STL_Extension
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Segment_Delaunay_graph_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Skin_surface_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Snap_rounding_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_searching
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_sorting
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Straight_skeleton_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Stream_lines_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Subdivision_method_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_parameterization
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_simplification
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesher
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_reconstruction_points_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Voronoi_diagram_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/examples/Width_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/AABB_tree
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Apollonius_graph_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Arrangement_on_surface_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Boolean_set_operations_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Bounding_volumes
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/CGAL_ipelets
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_d
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Envelope_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Generator
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Geomview
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/GraphicsView
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Interpolation
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Kinetic_data_structures
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/L1_Voronoi_diagram_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Largest_empty_rect_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Linear_cell_complex
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_2/Qt3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_S2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_3_triangulation_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_Lloyd_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Polygon
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron_IO
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Principal_component_analysis
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Segment_Delaunay_graph_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Snap_rounding_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Spatial_searching_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Straight_skeleton_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Stream_lines_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_mesher
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_reconstruction_points_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_2
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3
used as include directory in directory /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3_Geomview_demos
Configuring incomplete, errors occurred!
Em 2012-10-22 21:03, Péricles Lopes Machado escreveu:
Tu podes precisas instalar o pacote libgmp3-dev usando o comando:
sudo aptitude install libgmp3-dev
Atenciosamente,Péricles Lopes Machado"Uma verdade claramente compreendida não pode ser escrita com sinceridade."Marcel Proust
-- Luiz Ernesto F. Alves Bacharelado em Física - UFRGS
- [cgal-discuss] Problems to install CGAL-4.0.2, Luiz Ernesto F. Alves, 10/23/2012
- Re: [cgal-discuss] Problems to install CGAL-4.0.2, Péricles Lopes Machado, 10/23/2012
- Re: [cgal-discuss] Problems to install CGAL-4.0.2, Luiz Ernesto F. Alves, 10/23/2012
- Re: [cgal-discuss] Problems to install CGAL-4.0.2, Sebastien Loriot (GeometryFactory), 10/23/2012
- Re: [cgal-discuss] Problems to install CGAL-4.0.2, Marc Glisse, 10/23/2012
