cgal-discuss - Re: [cgal-discuss] Problems to install CGAL-4.0.2
  • To: "" <>
  • Subject: Re: [cgal-discuss] Problems to install CGAL-4.0.2
  • Date: Tue, 23 Oct 2012 09:40:53 +0200
You're missing boost library.
Try sudo apt-get install libboost-dev
Each error message tells you what is missing (optional dependancies does not trigger an error but a warning). You can keep on posting on the list but using your favorite search engine might be faster to find the package name.
I guess you'll need also libmpfr-dev.
Sebastien.
On Tuesday, October 23, 2012, Luiz Ernesto F. Alves <> wrote:
> Thanks!  Now I see that I have too many error messages, here is the Log from cmake:
> (I expect that these list have no characters limitation, I'm sorry about the huge log... )
> Build CGAL from release in directory CGAL-4.0.2
> Packagenames: CGAL-4.0.2
> CGAL_MAJOR_VERSION=4
> CGAL_MINOR_VERSION=0
> CGAL_BUGFIX_VERSION=2
> CGAL_SONAME_VERSION=9
> CGAL_SOVERSION =9.0.0
> CGAL_REFERENCE_CACHE_DIR=
> Building shared libraries
> Targetting Unix Makefiles
> Using /usr/bin/c++ compiler.
> USING CMake version: 2.8.7
> System: Linux
> USING GCC_VERSION = '4.6.3'
> Using gcc version 4 or later. Adding -frounding-math
> Build type: Release
> USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
> USING LDFLAGS = ' '
> GMPXX include: /usr/include
> GMPXX libraries: /usr/lib/i386-linux-gnu/libgmpxx.so
> GMP include: /usr/include
> GMP libraries: /usr/lib/i386-linux-gnu/libgmp.so
> GMP definitions:
> USING GMP_VERSION = '5.0.2'
> MPFR include: /usr/include
> MPFR libraries: /usr/lib/i386-linux-gnu/libmpfr.so
> MPFR definitions:
> USING MPFR_VERSION = '3.1.0'
> Found MPFI: /usr/lib/libmpfi.so
> MPFI include: /usr/include
> MPFI libraries: /usr/lib/libmpfi.so
> MPFI definitions:
> Could NOT find RS
> CMake Error at cmake/modules/FindBoost.cmake:917 (message):
> Unable to find the requested Boost libraries.
> Unable to find the Boost header files. Please set BOOST_ROOT to the root
> directory containing Boost or BOOST_INCLUDEDIR to the directory containing
> Boost's headers.
> Call Stack (most recent call first):
> cmake/modules/CGAL_SetupBoost.cmake:6 (find_package)
> cmake/modules/CGAL_SetupDependencies.cmake:32 (include)
> CMakeLists.txt:496 (include)
> Boost include: Boost_INCLUDE_DIR-NOTFOUND
> Boost libraries:
> Boost definitions:
> USING BOOST_VERSION = '..'
> Library config detected: Qt3
> CGAL_Qt3 needs Qt3, cannot be configured.
> Library config detected: ImageIO
> OpenGL include: /usr/include
> OpenGL libraries: /usr/lib/i386-linux-gnu/libGLU.so;/usr/lib/i386-linux-gnu/libGL.so;/usr/lib/i386-linux-gnu/libSM.so;/usr/lib/i386-linux-gnu/libICE.so;/usr/lib/i386-linux-gnu/libX11.so;/usr/lib/i386-linux-gnu/libXext.so
> USING ZLIB_VERSION = '1.2.3.4'
> ZLib include: /usr/include
> ZLib libraries: /usr/lib/i386-linux-gnu/libz.so
> Library config detected: Qt4
> USING QT4_VERSION = '4.8.1'
> OpenGL definitions:
> Qt4 include: /usr/include/qt4
> Qt4 libraries: /usr/lib/i386-linux-gnu/libQtOpenGL.so;/usr/lib/i386-linux-gnu/libQtGui.so;/usr/lib/i386-linux-gnu/libQtCore.so
> Qt4 definitions:
> moc executable: /usr/bin/moc-qt4
> uic executable: /usr/bin/uic-qt4
> Library config detected: Core
> Library configs detected: CGAL;Core;ImageIO;Qt3;Qt4
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/AABB_tree
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_foundations
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Algebraic_kernel_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Alpha_shapes_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Apollonius_graph_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Approximate_min_ellipsoid_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Arrangement_on_surface_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_arrangement_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_polyhedron_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/BGL_triangulation_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Boolean_set_operations_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Box_intersection_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/CGAL_ipelets
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/CGALimageIO
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circular_kernel_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Circulator
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Combinatorial_map
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_decomposition_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Convex_hull_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Core
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Developers_manual
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Envelope_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Filtered_kernel
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Generator
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/HalfedgeDS
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Interpolation
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Interval_skip_list
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Jet_fitting_3
> Could NOT find Eigen3 (missing: EIGEN3_INCLUDE_DIR EIGEN3_VERSION_OK) (Required is at least version "3.0.91")
> A library with BLAS API not found. Please specify library location.
> LAPACK requires BLAS.
> NOTICE: This program requires either Eigen 3.1 (or greater) or LAPACK, and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kernel_23
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_data_structures
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Kinetic_framework
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Largest_empty_rect_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Linear_cell_complex
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Matrix_search
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Mesh_3
> NOTICE: This program requires Boost >= 1.34.1, and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_annulus_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_circle_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_ellipse_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_quadrilateral_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Min_sphere_of_spheres_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Minkowski_sum_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Modular_arithmetic
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Nef_S2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Partition_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Periodic_3_triangulation_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Point_set_processing_3
> NOTICE: Some of the executables in this directory need either Eigen 3.1 (or greater) or LAPACK, and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polygon
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polyhedron_IO
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polynomial_kernel
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Polytope_distance_d
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Principal_component_analysis
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Profiling_tools
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/QP_solver
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/RangeSegmentTrees
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Ridges_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/STL_Extension
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Segment_Delaunay_graph_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Skin_surface_3
> NOTICE: skin_surface_pdb_reader.cpp requires ESBTL library, and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Snap_rounding_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_searching
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Spatial_sorting
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Straight_skeleton_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Stream_lines_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Subdivision_method_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_parameterization
> USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG -fno-strict-aliasing'
> USING EXEFLAGS = ' '
> TAUCS requires LAPACK and BLAS.
> NOTICE: Example Complete_parameterization_example.cpp requires Eigen 3.1 (or greater) and will not be compiled.
> NOTICE: Example Taucs_parameterization.cpp requires TAUCS and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesh_simplification
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_mesher
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Surface_reconstruction_points_3
> NOTICE: Example poisson_reconstruction_example.cpp needs Eigen 3.1 (or greater) or the TAUCS library and will not be compiled.
> NOTICE: Some of the executables in this directory need the TAUCS library and will not be compiled.
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Triangulation_3
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Voronoi_diagram_2
> Configuring examples in /home/mraxis/Downloads/CGAL-4.0.2/examples/Width_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/AABB_tree
> NOTICE: This demo requires QGLViewer, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Alpha_shapes_3
> NOTICE: This demo requires CGAL, the QGLViewer, OpenGL and Qt4, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Apollonius_graph_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Arrangement_on_surface_2
> NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Boolean_set_operations_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Bounding_volumes
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/CGAL_ipelets
> NOTICE: This program requires the Ipe include files and library, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Circular_kernel_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Convex_hull_d
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Envelope_3
> NOTICE: This demo requires Qt3 and the CGAL Qt3 library, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Generator
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Geomview
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/GraphicsView
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Interpolation
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Kinetic_data_structures
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/L1_Voronoi_diagram_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Largest_empty_rect_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Linear_cell_complex
> NOTICE: This demo requires CGAL, QGLViewer, OpenGL and Qt4, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Mesh_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Nef_S2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_3_triangulation_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Periodic_Lloyd_3
> NOTICE: This demo requires qcollectiongenerator, QGLViewer, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polygon
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Polyhedron_IO
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Principal_component_analysis
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Segment_Delaunay_graph_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Snap_rounding_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Spatial_searching_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Straight_skeleton_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Stream_lines_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_mesher
> NOTICE: This demo needs libQGLViewer, and will not be compiled.
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Surface_reconstruction_points_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_2
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3
> Configuring demo in /home/mraxis/Downloads/CGAL-4.0.2/demo/Triangulation_3_Geomview_demos
> CMake Error: The following variables are used in this project, but they are
