cgal-discuss - Re: [cgal-discuss] Joining faces of Voronoi map
  • To:
  • Subject: Re: [cgal-discuss] Joining faces of Voronoi map
  • Date: Mon, 29 Oct 2012 23:21:58 +0100
I would recommand to use this package [1] which deals with degenerate cases. To build faces, I recommand to use a halfedge_data_structure
instead, as the arrangement is already encoded in the triangulation [2].
For clipping Voronoi bisectors, the intersection function between
an Iso_rectangle_2 and Line_2 or Segment_2 of Ray_2 objects [3].
Sebastien
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Voronoi_diagram_2/Chapter_main.html
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/HalfedgeDS/Chapter_main.html
[3]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html
On 10/24/2012 02:05 PM, Martin Uhrin wrote:
Dear CGAL community,
I'm using a Delaunay triangulation using vertices with info to 'tag'
each vertex. For neighbouring vertices with the same tag I would like
to join the corresponding Voronoi faces. Eventually I plan to bound the
Voronoi diagram along the lines of this example:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Subsection_37.5.4
and extract the now bounded polygons corresponding to regions with the
same tag.
Currently my approach is roughly as follows:
1) Create triangulation, tagging each vertex
2) Create an Arrangement for each tag
3) Iterate over all (finite) Delaunay edges
4) if the two vertices of the edge do not share the same tag, insert the
corresponding Voronoi halfedge into the arrangement for each of the two tags
5) Iterate over all arrangements extracting the edges to get the joined
regions of the Voronoi for each tag
My questions are:
a) Is there any more intuitive a way to achieve my goals rather than
using arrangements?
b) Is there any way to get better performance? I've had to use an
Exact_predicates_exact_constructions_kernel because I was getting
precondition failures with inexact when adding edges to arrangements but
now this operation is very slow.
c) When I finally add the boundary to the Voronoi resulting in
(hopefully) there being only bounded polygons in the arrangements will I
be able to extract these as polygon objects or do I have to somehow
build the polygons myself?
Many thanks for your help,
-Maritn
Martin Uhrin Tel: +44
207 679 3466
Department of Physics & Astronomy Fax:+44 207 679 0595
University College London
<mailto:>
Gower St, London, WC1E 6BT, U.K. http://www.cmmp.ucl.ac.uk
<http://www.cmmp.ucl.ac.uk/>
