- To:
- Subject: Re: [cgal-discuss] Help with understanding boolops on Bezier polygons
- Date: Wed, 7 Nov 2012 19:37:31 +0200
That is an interesting idea.
On Wed, Nov 7, 2012 at 12:29 PM, Shriramana Sharma <> wrote:
Hi thanks all for your kind and informative replies. It would be great
to have at least some of the features headers-only (since CGAL uses
templates heavily anyway).
OK.
On Tue, Nov 6, 2012 at 4:49 PM, Efi Fogel <> wrote:
> The Bezier traits handles self intersections. This implies that an
> arrangement can be constructed given Bezier curves some of which are self
> intersecting.
> A (general) polygons which is the input to a Boolean operation is a
> different story. It must be simple. The exact definition appears in the
> manual, but I can tell you that it cannot self intersect.
Oh only now I observe that the types are entirely different. I'll see
>> /home/samjnaa/bn/cpp-cgal/boolean-test.cpp: In function ‘int main(int,
>> char**)’:
>> /home/samjnaa/bn/cpp-cgal/boolean-test.cpp:168:37: error: no matching
>> function for call to ‘print_polygon_with_holes(const
CGAL::General_polygon_with_holes_2<CGAL::General_polygon_2<CGAL::Arr_Bezier_curve_traits_2<CGAL::Cartesian<CORE::BigRat>,
>> CGAL::Cartesian<CORE::Expr>, CGAL::CORE_algebraic_number_traits> >
>> /home/samjnaa/bn/cpp-cgal/boolean-test.cpp:168:37: note: candidate is:
>> /home/samjnaa/bn/cpp-cgal/print_utils.h:27:6: note: template<class
>> Kernel, class Container> void print_polygon_with_holes(const
>> CGAL::Polygon_with_holes_2<Kernel_, Container_>&)
what I can do.
BTW it would be good if the polygons could use operator << and not
just push_back to add points -- it would make programming so much
easier, no?
polygon << Point_2(10,10) << Point_2(20,30) ... ;
Shriramana Sharma
- [cgal-discuss] Help with understanding boolops on Bezier polygons, Shriramana Sharma, 11/06/2012
- [cgal-discuss] Re: Help with understanding boolops on Bezier polygons, Shriramana Sharma, 11/06/2012
- Re: [cgal-discuss] Re: Help with understanding boolops on Bezier polygons, Philipp Moeller, 11/06/2012
- Re: Re: [cgal-discuss] Re: Help with understanding boolops on Bezier polygons, Laurent Rineau (CGAL/GeometryFactory), 11/06/2012
- Re: [cgal-discuss] Help with understanding boolops on Bezier polygons, Efi Fogel, 11/06/2012
- Re: [cgal-discuss] Help with understanding boolops on Bezier polygons, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Help with understanding boolops on Bezier polygons, Ophir Setter, 11/07/2012
