- To:
- Subject: Re: [cgal-discuss] Effect of orientation on boolops
- Date: Wed, 7 Nov 2012 18:38:38 +0200
What does need an explanation?
The polygon Q in the second case is invalid. All bets are off.
On Wed, Nov 7, 2012 at 4:05 PM, Shriramana Sharma <> wrote:
On Wed, Nov 7, 2012 at 6:25 PM, Efi Fogel <> wrote:If so, can you please explain this (see the points of Q in the second case):
> There is no such thing as a CW oriented (valid) polygon.
$ ./do_intersect
P = [ 3 vertices: (-1 1) (0 -1) (1 1) ]
Q = [ 3 vertices: (-1 -1) (1 -1) (0 1) ]
The two polygons intersect in their interior.
$ ./do_intersect-alt
Q = [ 3 vertices: (0 1) (1 -1) (-1 -1) ]
Shriramana Sharma
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
_/
- [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Sebastien Loriot (GeometryFactory), 11/08/2012
- Message not available
- RE: [cgal-discuss] Effect of orientation on boolops, Moore Rollo (THE ROYAL MARSDEN NHS FOUNDATION TRUST), 11/12/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/13/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/14/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Sebastien Loriot (GeometryFactory), 11/14/2012
