- To:
- Subject: Re: [cgal-discuss] Bug in Circular_kernel_2
- Date: Fri, 09 Nov 2012 16:31:47 +0100
On 09/11/2012 15:09, Philipp Moeller wrote:
Marc Mörig
writes:
Dear CGAL maintainers,
for comparison purposes I use the following combination of
kernels/traits to compute arrangements of circles:
typedef CGAL::Exact_predicates_exact_constructions_kernel Linear_k;
typedef Linear_k::FT NT;
typedef CGAL::Algebraic_kernel_for_circles_2_2<NT> Algebraic_k;
typedef CGAL::Circular_kernel_2<Linear_k,Algebraic_k> Circular_k;
typedef CGAL::Arr_circular_line_arc_traits_2<Circular_k> Traits;
The compiler warns about returning temporaries by reference in several
places, eg
/scratch/LIBS/CGAL/CGAL-4.0.2/include/CGAL/Circle_2.h:107:55: warning:
returning reference to temporary [enabled by default]
In this and other places, there is a Qualified_result_of mechanism
which seems to be not working, while in other places there is not. If
I modify CGAL code to return by value in all places the compiler warns
about I get working code. This may however result in inefficiencies
for
other use cases.
Which CGAL version are you using? Qualified_result_of has been removed
in CGAL 4.1.
4.0.2
- [cgal-discuss] Bug in Circular_kernel_2, Marc Mörig, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Philipp Moeller, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Andreas Fabri, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Marc Mörig, 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Sebastien Loriot (GeometryFactory), 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Bhudev Kumar, 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Sebastien Loriot (GeometryFactory), 11/13/2012
