- To:
- Subject: Re: [cgal-discuss] Bug in Circular_kernel_2
- Date: Tue, 13 Nov 2012 10:55:51 +0100
This is indeed a bug in CGAL while using Exact_predicates_exact_constructions_kernel with the circular kernel.
We will provide a complete patch soon. In the meantime removing the
reference as you did is correct but not optimal if you change the kernel.
Thanks for the report,
Sebastien.
On 11/12/2012 04:28 PM, Marc Mörig wrote:
I have attached some code plus an input file. Place both in the same
directory.
On 11/12/2012 04:05 PM, Sebastien Loriot (GeometryFactory) wrote:
Hi Marc,
would you have a small but complete example showing the problem?
Sebastien.
- [cgal-discuss] Bug in Circular_kernel_2, Marc Mörig, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Philipp Moeller, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Andreas Fabri, 11/09/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Marc Mörig, 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Sebastien Loriot (GeometryFactory), 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Bhudev Kumar, 11/12/2012
- Re: [cgal-discuss] Bug in Circular_kernel_2, Sebastien Loriot (GeometryFactory), 11/13/2012
