- To:
- Subject: Re: [cgal-discuss] Effect of orientation on boolops
- Date: Wed, 14 Nov 2012 17:14:06 +0530
On Wed, Nov 14, 2012 at 5:05 PM, Sebastien Loriot (GeometryFactory)
wrote:
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html#Subsection_19.2.1
> http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html#Subsection_19.2.2
Hi -- it is because I've already read the above that I started this
thread. My point is that the above documentation only states the
conditions for valid polygons, but does not explicitly warn what would
be the result of using invalid polygons.
As I pointed out earlier, some operations apparently do work correctly
on "invalid" polygons, but it is that there is no guarantee that *all*
operations will work correctly. IMHO it would be useful to warn the
user about that.
Shriramana Sharma
- Re: [cgal-discuss] Effect of orientation on boolops, (continued)
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/07/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/08/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Sebastien Loriot (GeometryFactory), 11/08/2012
- Message not available
- RE: [cgal-discuss] Effect of orientation on boolops, Moore Rollo (THE ROYAL MARSDEN NHS FOUNDATION TRUST), 11/12/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Efi Fogel, 11/13/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Shriramana Sharma, 11/14/2012
- Re: [cgal-discuss] Effect of orientation on boolops, Sebastien Loriot (GeometryFactory), 11/14/2012
