cgal-discuss - Re: [cgal-discuss] Effect of orientation on boolops
  • To:
  • Subject: Re: [cgal-discuss] Effect of orientation on boolops
  • Date: Thu, 08 Nov 2012 09:29:11 +0100
On 11/08/2012 09:10 AM, Shriramana Sharma wrote:
On Thu, Nov 8, 2012 at 1:19 PM, Efi
Fogel<>
wrote:
In all ways whatsoever.
I'm sorry but I am not able to understand much from the above
statement. Could you please show me an example of a predicate or an
operation which would work correctly with "correctly" oriented
polygons and not work with "incorrectly" oriented ones?
Thank you for your patience,
You got the validity conditions here [1].
From [1], you can see that Polygon_2 as a method is_simple() and a orientation() method.
Polygon_with_holes_2 does not have a is_simple member function but
the global function is_simple can be used for outer boundary and holes [2].
Sebastien.
[0] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Boolean_set_operations_2/Chapter_main.html#Section_19.2
[1]http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polygon_ref/Class_Polygon_2.html
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polygon_ref/Function_is_simple_2.html
