- To: "" <>
- Subject: Re: [cgal-discuss] learning CGAL and include lib
- Date: Wed, 14 Nov 2012 08:27:32 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=V5vuZwcCUZA4nWqTvsEOFDQ3KoYvnFIWSylN+OORl32GquKne0QgsGuhFpIJZyVVqLrLM2bO/rVJeocxDEMwG+bJjzrHRdZqaYwpZ+1Jd87F51ms9vTJLp2gnXzJ/y8AaYjst4iAi90k2AuNt7tA0cP2lvHxApu+W0FZVc+igf0=;
hi , thanks alot.
Fortunately this time I succeeds to run the demo . I run .exe file in matlab environment and saw the demo and meshes.
but in visual studio when I want to debug the solution there is an error about not finding .dll in *86 folder.
I have copied include/CGAL in my opencv folder since I have set a .properties file to add any project and for setting include file but I don't know what is the better way for it.
To:
Sent: Wednesday, November 14, 2012 8:06 AM
So as you told before you must go step by step. First you must put you cgal library
working properly with VS 2010.
do you follow the 6th
(of http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows)
When you say "it can not run and end immediately." What is the error that appears?
6) Sanity check
- Open CMake (cmake-gui, can be found on the desktop) - (for win7 users, use "Run as admin")
- Choose "Where is the source code:" to be the Triangulation_2
demo directory under the CGAL installation. Namely,
<CGAL>/demo/Triangulation_2 (C:/Program
Files/CGAL-3.9 /demo/Triangulation_2).
- Choose "Where to build the binaries:" to the same directory.
- Click Configure
- Click Generate
- Go to the directory (C:\Program Files\CGAL-3.9) and open the
solution and compile. Run the Delaunay_triangulation project for check
(in debug and release)
2012/11/14 sara ershadi <>
hi ,No , I have already build some example in CGAL . I first make .sln file with Cmake 2.8 and then open it with visual studio 2010 and build the solution. .exe file also created in debug folder but usually it can not run and end immediately.I have learn CGAL till this point until now.
To:
Sent: Wednesday, November 14, 2012 7:39 AM
And do do you have already load (or define) the mesh?2012/11/14 sara ershadi <>
My Goal in CGAL in 3D reconstruction human pose . but I want to do it step by step . I want now have a mesh of interest point .
To:
Sent: Wednesday, November 14, 2012 5:32 AM
On Wed, Nov 14, 2012 at 6:12 PM, sara <> wrote:
> I am a CGAL beginner , I wnat to use CGAL function . what is your suggestion
Hello. Please state clearly what exactly you want to do using CGAL.
Then the people here would be better able to help you.
Shriramana Sharma
- [cgal-discuss] learning CGAL and include lib, sara, 11/14/2012
- Re: [cgal-discuss] learning CGAL and include lib, Shriramana Sharma, 11/14/2012
- Re: [cgal-discuss] learning CGAL and include lib, sara ershadi, 11/14/2012
- Re: [cgal-discuss] learning CGAL and include lib, Roberto Lam, 11/14/2012
- [cgal-discuss] Re: learning CGAL and include lib, sara, 11/15/2012
- Re: [cgal-discuss] learning CGAL and include lib, Clément Jamin, 11/15/2012
- Re: [cgal-discuss] learning CGAL and include lib, sara ershadi, 11/15/2012
