cgal-discuss - Re: [cgal-discuss] learning CGAL and include lib
  • To:
  • Subject: Re: [cgal-discuss] learning CGAL and include lib
  • Date: Wed, 14 Nov 2012 16:06:08 +0000
So as you told before you must go step by step. First you must put you cgal library
working properly with VS 2010.
do you follow the 6th
(of http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows)
6) Sanity check
 - Open CMake (cmake-gui, can be found on the desktop) - (for win7 users, use "Run as admin")
 - Choose "Where is the source code:" to be the Triangulation_2 demo directory under the CGAL installation. Namely, <CGAL>/demo/Triangulation_2 (C:/Program Files/CGAL-3.9 /demo/Triangulation_2).
 - Choose "Where to build the binaries:" to the same directory.
 - Click Configure
 - Click Generate
 - Go to the directory (C:\Program Files\CGAL-3.9) and open the solution and compile. Run the Delaunay_triangulation project for check (in debug and release)
When you say "it can not run and end immediately." What is the error that appears?
2012/11/14 sara ershadi <>
hi ,
No , I have already build some example in CGAL . I first make .sln file with Cmake 2.8 and then open it with visual studio 2010 and build the solution. .exe file also created in debug folder but usually it can not run and end immediately.
I have learn CGAL till this point until now.
To:
Sent: Wednesday, November 14, 2012 7:39 AM
And do do you have already load (or define) the mesh?
My Goal in CGAL in 3D reconstruction human pose . but I want to do it step by step . I want now have a mesh of interest point .
To:
Sent: Wednesday, November 14, 2012 5:32 AM
On Wed, Nov 14, 2012 at 6:12 PM, sara <> wrote:
> I am a CGAL beginner , I wnat to use CGAL function . what is your suggestion
Hello. Please state clearly what exactly you want to do using CGAL.
Then the people here would be better able to help you.
Shriramana Sharma
