- To: croatoan <>
- Cc:
- Subject: Re: [cgal-discuss] pod types
- Date: Sun, 25 Nov 2012 13:06:07 +0100
croatoan
writes:
> hi to all.
> is there any way to work with all cgal types as if there were pod types.. eg
> a function that let me take a reference to internal representation as pod or
> something like that... i need pod for io on disk and operators << and >> are
> not an option (only raw transfer of bits using write() and read())
Can you be a little bit more specific about the types? There are quite a
lot in CGAL and that is certainly different from type to type. A
concrete example would be helpful.
For most types I'm not even sure that this kind of serialization makes
sense.
- [cgal-discuss] pod types, croatoan, 11/25/2012
- Re: [cgal-discuss] pod types, Philipp Moeller, 11/25/2012
- [cgal-discuss] Re: pod types, croatoan, 11/25/2012
- Re: [cgal-discuss] Re: pod types, Philipp Moeller, 11/25/2012
