- To: croatoan <>
- Cc:
- Subject: Re: [cgal-discuss] Re: pod types
- Date: Sun, 25 Nov 2012 13:34:11 +0100
croatoan
writes:
> yes you are write... it makes sense to involve only objects from the
> Geometry
> Kernels.. the basic objects.. Points, Lines, Circles, etc
> e.g consider implementing a external sort using a cgal Point as a data type.
> Without loosing the benefits that cgal provides for its number types
Unfortunately none of the basic kernels (Simple_*) make any guarantees
about how their objects are laid out. You can probably take a look at
the individual classes and decide if you can serialize what is there
with Cartesian_const_iterator or by accessing the right
coordinates. This will be rather fragile, do it at your own peril.
The whole idea seems difficult for reference counted and impossible for
Lazy kernels.
- [cgal-discuss] pod types, croatoan, 11/25/2012
- Re: [cgal-discuss] pod types, Philipp Moeller, 11/25/2012
- [cgal-discuss] Re: pod types, croatoan, 11/25/2012
- Re: [cgal-discuss] Re: pod types, Philipp Moeller, 11/25/2012
