- To:
- Subject: [cgal-discuss] Creating a Medial Axis for a Polygon
- Date: Mon, 26 Nov 2012 07:03:19 -0800 (PST)
Hello,
I need to write code that will determine the medial axis for a polygon. I
have been using CGAL for the past couple of weeks, and have been able to
implement code that calculates a Voronoi diagram for a set of points and a
straight skeleton for a polygon, but I am having trouble figuring out how to
calculate a medial axis. I have seem some references suggesting that I need
to start with a segment Voronoi diagram, but I haven't been able to
determine how to do that using CGAL. Unfortunately, I am not an expert in
computational geometry, so it is possible that this process is pretty
straightforward, but I am just not getting it.
Can someone post (or point me to) a code sample that calculates the medial
axis of a polygon?
Thank you.
Bob
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Creating-a-Medial-Axis-for-a-Polygon-tp4656314.html
- [cgal-discuss] Creating a Medial Axis for a Polygon, Bob Cave, 11/26/2012
- [cgal-discuss] Re: Creating a Medial Axis for a Polygon, ayongwust_sjtu, 11/27/2012
