cgal-discuss - [cgal-discuss] Re: Intersection of surfaces
  • To:
  • Subject: [cgal-discuss] Re: Intersection of surfaces
  • Date: Mon, 26 Nov 2012 12:37:40 -0800 (PST)
Hello,
On 07/27/2012 03:07 PM, vicn1222 [via cgal-discuss] wrote:
> I have exactly same question:
> I need to find intersection of a terrain (such as earth surface) with
> a plane (such as a vertical XZ plane perpendicular to Y axis).
> Assuming the terrain is defined by a set of (x, y, z), and the plane
> is defined by a point (x1, y1, z1) and a normal (x2, y2, z2), where
> the point lies on the plane, and normal is perpendicular to it. The
> normal doesn't have to be normalized. I need to find their
> intersection...
> I know CGAL can do the job. However, the typedef and the complexity of
> the template is beyond my imagination....
> Could someone please help me out the code? Even if you point me to a
> document, it won't help, as I have already looked through this thread
> for a long time....
Sorry for the sloooow reply: your e-mail re-surfaced as I was tidying up
my mailboxes.
I gave up.  Maybe one day I will figure out how to make good and proper
use of CGAL, but I don't have time to spends days to weeks on this.
Good luck.
Roger
This electronic communication is governed by the terms and conditions at
http://www.mun.ca/cc/policies/electronic_communications_disclaimer_2012.php
View this message in context: Re: Intersection of surfaces
  • [cgal-discuss] Re: Intersection of surfaces, Roger Mason, 11/26/2012
