- To: ,
- Subject: Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3
- Date: Wed, 28 Nov 2012 10:23:57 +0100
Hello Andreas, hello to all,
Thanks for you quick reaction :-)
Le 27/11/2012 21:47, Andreas Fabri a écrit :
To get the graphicsitem compiled, it would be enough to throw out
Ray, Line, Iso_rectangle from the classes
CGAL::Qt::Converter, which converts CGAL and Qt points,...
CGAL::Qt::Painter_ostream, which calls the Qt drawing functions.
I write "enough", as you are looking for a quick hack.
I fear I don't grasp enough of the CGAL::Qt and GeometricTraits (yet) to fully understand your "quick hack".
Do you mean I should write myself specialization of the CGAL::Qt::Converter template for the Point_3 class, which get aliased to Point_2 by the projection_xy_3 traits ?
Which part of this code would belong to the Geometric Traits, to CGAL::QT or to my own code ?
I would have expected naively that the projection_xy_3 trait would convert the Point_3 into Point_2, but this seems not being the case. Should this operation really happen in CGAL::Qt::Converter ?
Thanks for your consideration.
Best regards,
Anthony Truchet
Engineer with Logilab SA - www.logilab.fr
- [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3, Anthony Truchet, 11/27/2012
- Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3, Andreas Fabri, 11/27/2012
- Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3, Anthony Truchet, 11/28/2012
- Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3, Andreas Fabri, 11/28/2012
