cgal-discuss - Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3
  • To:
  • Subject: Re: [cgal-discuss] CGAL_Qt4 and CGAL::Projection_traits_xy_3
  • Date: Wed, 28 Nov 2012 15:45:05 +0100
On 28/11/2012 10:23, Anthony Truchet wrote:
Hello Andreas, hello to all,
Thanks for you quick reaction :-)
Le 27/11/2012 21:47, Andreas Fabri a écrit :
To get the graphicsitem compiled, it would be enough to throw out
Ray, Line, Iso_rectangle from the classes
CGAL::Qt::Converter, which converts CGAL and Qt points,...
CGAL::Qt::Painter_ostream, which calls the Qt drawing functions.
I write "enough", as you are looking for a quick hack.
I fear I don't grasp enough of the CGAL::Qt and GeometricTraits (yet) to
fully understand your "quick hack".
As you work for a company: buy commercial support.
Best regards,
Andreas
Do you mean I should write myself specialization of the
CGAL::Qt::Converter template for the Point_3 class, which get aliased to
Point_2 by the projection_xy_3 traits ?
Which part of this code would belong to the Geometric Traits, to
CGAL::QT or to my own code ?
I would have expected naively that the projection_xy_3 trait would
convert the Point_3 into Point_2, but this seems not being the case.
Should this operation really happen in CGAL::Qt::Converter ?
Thanks for your consideration.
Best regards,
Anthony Truchet
Engineer with Logilab SA - www.logilab.fr
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
