- To:
- Subject: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron
- Date: Thu, 29 Nov 2012 06:42:43 -0800 (PST)
Hi all,
I have now a problem on finding shortest path between two vertices on the
surface graph of polyhedron. I tried to apply "the surface of polyhedron as
model of the Boost graph" and then use Dijkstra algorithm but it doesn't
work. So someone please give any suggestion?
Thank you in advance.
Bests,
Trang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Dijkstra-s-algorithm-on-surface-graph-of-a-polyheron-tp4656323.html
- [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, lhtrang, 11/29/2012
- Re: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, Philipp Moeller, 11/29/2012
- Re: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, Andreas Fabri, 11/29/2012
