- To:
- Subject: Re: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron
- Date: Thu, 29 Nov 2012 15:58:06 +0100
Hello,
As boost::kruskal_minimum_spanning_tree in
examples/BGL_polyhedron_3/kruskal.cpp
works, I suspect that the error is on your side.
What does your code look like?
andreas
On 29/11/2012 15:42, lhtrang wrote:
Hi all,
I have now a problem on finding shortest path between two vertices on the
surface graph of polyhedron. I tried to apply "the surface of polyhedron as
model of the Boost graph" and then use Dijkstra algorithm but it doesn't
work. So someone please give any suggestion?
Thank you in advance.
Bests,
Trang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Dijkstra-s-algorithm-on-surface-graph-of-a-polyheron-tp4656323.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, lhtrang, 11/29/2012
- Re: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, Philipp Moeller, 11/29/2012
- Re: [cgal-discuss] Dijkstra's algorithm on surface graph of a polyheron, Andreas Fabri, 11/29/2012
