- To:
- Subject: [cgal-discuss] Anyone could help me on mesh_3_plugin loading error?
- Date: Thu, 29 Nov 2012 07:19:18 -0800 (PST)
All built on Mesh_3 is right, but there was an exception that is not handled
when Mesh_3 was loading mesh_3_plugin. The calling stack where the interrupt
happened is described as the following pic.
<http://cgal-discuss.949826.n4.nabble.com/file/n4656326/error.png>
The codes in qobject.h are
template <class T>
inline T qobject_cast(QObject *object)
#if !defined(QT_NO_QOBJECT_CHECK)
reinterpret_cast<T>(object)->qt_check_for_QOBJECT_macro(*reinterpret_cast<T>(object));
#endif
* return
static_cast<T>(reinterpret_cast<T>(object)->staticMetaObject.cast(object));*}
The codes in Polyhedron_demo_mesh_3_plugin.cpp are:
bool applicable() const {
*return
qobject_cast<Scene_polyhedron_item*>(scene->item(scene->mainSelectionIndex()));*
The codes in Mainwindow.cpp are:
bool MainWindow::initPlugin(QObject* obj)
QObjectList childs = this->children();
Plugin_interface* plugin =
qobject_cast<Plugin_interface*>(obj);
if(plugin) {
// Call plugin's init() method
* plugin->init(this, this->scene, this);*
Q_FOREACH(QAction* action, plugin->actions()) {
// If action does not belong to the menus, add it to "Operations" menu
if(!childs.contains(action)) {
ui->menuOperations->addAction(action);
// Show and enable menu item
addAction(action);
return true;
The bold codes are interrupt point.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Anyone-could-help-me-on-mesh-3-plugin-loading-error-tp4656326.html
- [cgal-discuss] Anyone could help me on mesh_3_plugin loading error?, Ephemera, 11/29/2012
- Re: [cgal-discuss] Anyone could help me on mesh_3_plugin loading error?, Laurent Rineau (CGAL/GeometryFactory), 11/29/2012
