- To:
- Subject: Re: [cgal-discuss] Re: Can CGAL deal with STL file format?
- Date: Wed, 05 Dec 2012 09:46:25 +0100
Hello,
For the definition of the STL have a look at
http://en.wikipedia.org/wiki/STL_%28file_format%29
Attached you find a small program that converts a binary STL file
to an ascii OFF file.
Note that it ignores the normals.
Note also that in the code you find a brute force snapping,
as the data I had to convert had little gaps and overlaps of
triangles because points where not identical.
It should be straightforward to combine the code with the
Incremental Builder
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_25.6.2
At least if your triangles represent a surface, and are
oriented correctly.
Best regards,
Andreas
On 05/12/2012 09:29, areslp wrote:
Hi,
You can convert stl file to off file by Trimesh(c++), OpenMesh(c++),
Graph toolbox(matlab), Meshlab(Gui) etc. It's really simple to do it.
Best Regards,
Areslp
<mailto:>
*Date:* 2012-12-05 15:38
*To:* cgal-discuss
<mailto:>
*Subject:* Re: [cgal-discuss] Re: Can CGAL deal with STL file format?
Hi, Xianyong,
Thanks for your reply.
STL (STereoLithography) is a file format native to the
stereolithography CAD software created by 3D Systems. it is widely used
for rapid prototyping and computer-aided manufacturing. STL files
describe only the surface geometry of a three dimensional object without
any representation of color, texture or other common CAD model attributes.
Yes, CGAL surport the IO of OFF file very well. Maybe CGAL
haven't implement such an interface for STL file.
Best
Huayi
2012/12/5 ayongwust_sjtu
<mailto:>>
What do you mean of STL file format.
You can refer to Polyheron_3 example to read/write .off model file.
CGAL is a computational geometry library, therefore, it does not
care about
read/write file matters.
Regards,
Xianyong Liu
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Can-CGAL-deal-with-STL-file-format-tp4656337p4656338.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
#include <boost/cstdint.hpp> #include "boost/tuple/tuple.hpp" #include <iostream> #include <fstream> #include <map> #include <vector> #include <CGAL/Simple_cartesian.h> #include <CGAL/compute_average_spacing.h> typedef CGAL::Simple_cartesian<double> K; typedef K::Point_3 Point_3; int main(int argc, char* argv[]) { std::ifstream obj(argv[1], std::ios::in | std::ios::binary); for(int i=0; i < 80; i++){ boost::uint8_t c; obj.read(reinterpret_cast<char*>(&c), sizeof(c)); std::cerr << c; } std::cerr << std::endl; boost::uint32_t N32; obj.read(reinterpret_cast<char*>(&N32), sizeof(N32)); unsigned int N = N32; std::cerr << N << " triangles" << std::endl; std::vector<Point_3> points; std::map<Point_3,int> pmap; typedef boost::tuple<int,int,int> Face; std::vector<Face> faces; faces.reserve(N); int number_of_points = 0; int number_of_snapped_points = 0; for(int i=0; i < N; i++){ float normal[3]; obj.read(reinterpret_cast<char*>(&normal[0]), sizeof(normal[0])); obj.read(reinterpret_cast<char*>(&normal[1]), sizeof(normal[1])); obj.read(reinterpret_cast<char*>(&normal[2]), sizeof(normal[2])); int index[3]; for(int j=0; j < 3; j++){ float x,y,z; obj.read(reinterpret_cast<char*>(&x), sizeof(x)); obj.read(reinterpret_cast<char*>(&y), sizeof(y)); obj.read(reinterpret_cast<char*>(&z), sizeof(z)); Point_3 p(x,y,z); if(pmap.find(p)== pmap.end()){ // check brute force if there is a close point bool found_close_point = false; for(int k = 0; k < points.size(); k++){ if(sqrt(CGAL::squared_distance(p,points[k])) < 0.00001){ index[j] = k; found_close_point = true; number_of_snapped_points++; } } if(! found_close_point){ points.push_back(p); index[j] = number_of_points; pmap[p]= number_of_points++; } } else { index[j] = pmap[p]; } } faces.push_back(boost::make_tuple(index[0],index[1],index[2])); char c; obj.read(reinterpret_cast<char*>(&c), sizeof(c)); obj.read(reinterpret_cast<char*>(&c), sizeof(c)); } std::cerr << number_of_snapped_points << " snapped points" << std::endl; std::cout.precision(20); #if 0 CGAL::compute_average_spacing(points.begin(),points.end(),1); return 0; #endif std::cout << "OFF\n" << points.size() << " " << faces.size() << " 0" << std::endl; for(int i=0; i < points.size(); i++){ std::cout << points[i] << std::endl; } for(int i=0; i < faces.size(); i++){ std::cout << "3 " << boost::get<0>(faces[i]) << " " << boost::get<1>(faces[i]) << " " << boost::get<2>(faces[i]) << std::endl; } return 0; }
- [cgal-discuss] Can CGAL deal with STL file format?, 魏华祎, 12/05/2012
- [cgal-discuss] Re: Can CGAL deal with STL file format?, ayongwust_sjtu, 12/05/2012
- Re: [cgal-discuss] Re: Can CGAL deal with STL file format?, 魏华祎, 12/05/2012
- Re: Re: [cgal-discuss] Re: Can CGAL deal with STL file format?, areslp, 12/05/2012
- Re: [cgal-discuss] Re: Can CGAL deal with STL file format?, Andreas Fabri, 12/05/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] Can CGAL deal with STL file format?, 帝林, 12/05/2012
- Re: [cgal-discuss] Can CGAL deal with STL file format?, Richard Downe, 12/05/2012
- Re: [cgal-discuss] Can CGAL deal with STL file format?, 魏华祎, 12/06/2012
