cgal-discuss - Re: [cgal-discuss] Can CGAL deal with STL file format?
  • To:
  • Subject: Re: [cgal-discuss] Can CGAL deal with STL file format?
  • Date: Thu, 6 Dec 2012 11:46:01 +0800
Many thanks to all of you.
Best
Huayi
2012/12/5 Richard Downe <>
STL is stereolithography, used by 3D systems.
Huayi, I don't believe it does, but here's a function I wrote to write Polyhedron_3 surfaces out as STL, I hope it helps.
(The block around if (caps) { } is used for deleting endcaps, prior to generating CFD compatible tetrahedral volumes in downstream processing -- you can ignore that, it uses a struct I created with a bounding box and a normal to identify the flow extensions and endcaps correctly.)
-richard
On 12/05/2012 01:31 AM, 帝林 wrote:
什么是标准文件格式?
what is stl file format@_@
发自我的小米手机
魏华祎 <>编写:
Hi, Everyone,
      Is  CGAL able to read or write triangular surface mesh into STL file
format?  I can't find it in CGAL Document.
Best
Huayi
