- To:
- Subject: [cgal-discuss] Re: File_scanner_OFF problem
- Date: Thu, 13 Dec 2012 08:11:38 -0800 (PST)
To generate the makefile I simply did cmake . in the main directory and I did
the same in the example directory.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/File-scanner-OFF-problem-tp4656396p4656399.html
- [cgal-discuss] File_scanner_OFF problem, Noura, 12/13/2012
- Re: [cgal-discuss] File_scanner_OFF problem, Philipp Moeller, 12/13/2012
- [cgal-discuss] Re: File_scanner_OFF problem, Noura, 12/13/2012
