cgal-discuss - Re: [cgal-discuss] mesh example?
  • To:
  • Subject: Re: [cgal-discuss] mesh example?
  • Date: Thu, 13 Dec 2012 17:09:03 +0100
Hello,
If you look for how Mesh_3 is used in demo code,
you find it in the Polyhedron package.
Best,
andreas
On 13/12/2012 17:05, Randy Heiland wrote:
Thanks! I had only looked in /demo, where /Mesh_3 was essentially
empty. But now I see I can build several pgms in /examples/Mesh_3 and
just need to figure out how they work :)
On Wed, Dec 12, 2012 at 11:53 PM, Hamid G
<mailto:>>
wrote:
There are good examples in CGAL/examples/Mesh_3 for both cases that
you are after.
I am not familiar with 3Dircad dataset, but I noticed that you are
running you are code from "Mesh_2" directory, is that just a coincident?
On Wed, Dec 12, 2012 at 9:59 AM, Randy Heiland
<mailto:>>
wrote:
Hello, Can someone point me to an example use of generating a
3D tetrahedral mesh from either input points/polyhedra or a
stack of images?
I blindly tried this (after downloading the 3Dircad* dataset),
which seemed to run several seconds, but apparently produced no
output:
~/dev/CGAL/CGAL_build/demo/Mesh_2$ mesh 3Dircadb2.1/MESHES_VTK.zip
# Shewchuk Triangle .poly file, produced by the CGAL::Mesh_2
package
# Neither attributes nor boundary markers are used.
0 2 0 0
0 0
Mesh points: 0
Mesh triangles: 0
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
