cgal-discuss - Re: [cgal-discuss] Triangulation 2 stack overflow
  • To:
  • Subject: Re: [cgal-discuss] Triangulation 2 stack overflow
  • Date: Mon, 07 Jan 2013 08:16:29 +0100
This has already been fixed and will be out with the next release of CGAL.
Have a try with the patched file attached.
Sebastien.
On 01/03/2013 11:10 AM, Marek wrote:
hi
my name is Marek
i have question about Constrained_Delaunay_Triangulation_2. With some input
data stack got overflowed with conflict propagations:
template<class OutputItFaces, class OutputItBoundaryEdges>
std::pair<OutputItFaces,OutputItBoundaryEdges>
propagate_conflicts (const Point&p,
Face_handle fh,
int i,
std::pair<OutputItFaces,OutputItBoundaryEdges> pit) const
in some sort of infinite recursion
In my example I have geometry with features very close to each other ( inner
segment very close to meshing polygon contour segment), could you advise me
how can I made myself sure stack wont overflow for any geometry? I would like
to somehow detect that my geometry cant be meshed or use some tools to
preprocess it to be 100% sure it wont stuck.
also in this topic:
https://sympa.inria.fr/sympa/arc/cgal-discuss/2011-05/msg00172.html
I read that "There have been some work done in Triangulation_2 and
Triangulation_3, during the last two releases, because there was recursive
functions to compute the conflict zone of new point, and we removed those
recursions" , could u give me some more insights? I'm currently using CGAL 3.9
because company I work for have commercial license for it.
Marek
// Copyright (c) 1997  INRIA Sophia-Antipolis (France).
// All rights reserved.
// This file is part of CGAL (www.cgal.org).
// You can redistribute it and/or modify it under the terms of the GNU
// General Public License as published by the Free Software Foundation,
// either version 3 of the License, or (at your option) any later version.
// Licensees holding a valid commercial license may use this file in
// accordance with the commercial license agreement provided with the software.
// This file is provided AS IS with NO WARRANTY OF ANY KIND, INCLUDING THE
// WARRANTY OF DESIGN, MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
// $URL$
// $Id$
// Author(s)     : Mariette Yvinec, Jean Daniel Boissonnat
#ifndef CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
#define CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
#include <CGAL/triangulation_assertions.h>
#include <CGAL/Constrained_triangulation_2.h>
namespace CGAL {
template <class Gt,
          class Tds = Triangulation_data_structure_2 <
                      Triangulation_vertex_base_2<Gt>,
		      Constrained_triangulation_face_base_2<Gt> >,
	  class Itag = No_intersection_tag >
class Constrained_Delaunay_triangulation_2
  : public  Constrained_triangulation_2<Gt, Tds, Itag>
public:
  typedef Constrained_triangulation_2<Gt,Tds,Itag>             Ctr;
  typedef Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>    CDt;
  typedef typename Ctr::Geom_traits      Geom_traits;
  typedef typename Ctr::Intersection_tag Intersection_tag;
  typedef typename Ctr::Constraint    Constraint;
  typedef typename Ctr::Vertex_handle Vertex_handle;
  typedef typename Ctr::Face_handle   Face_handle;
  typedef typename Ctr::Edge          Edge;
  typedef typename Ctr::Finite_faces_iterator Finite_faces_iterator;
  typedef typename Ctr::Face_circulator       Face_circulator;
  typedef typename Ctr::size_type             size_type;
  typedef typename Ctr::Locate_type           Locate_type;
  typedef typename Ctr::List_edges List_edges;
  typedef typename Ctr::List_faces List_faces;
  typedef typename Ctr::List_vertices  List_vertices;
  typedef typename Ctr::List_constraints List_constraints;
  typedef typename Ctr::Less_edge less_edge;
  typedef typename Ctr::Edge_set Edge_set;
#ifndef CGAL_CFG_USING_BASE_MEMBER_BUG_2
  using Ctr::geom_traits;
  using Ctr::number_of_vertices;
  using Ctr::finite_faces_begin;
  using Ctr::finite_faces_end;
  using Ctr::dimension;
  using Ctr::cw;
  using Ctr::ccw;
  using Ctr::infinite_vertex;
  using Ctr::side_of_oriented_circle;
  using Ctr::is_infinite;
  using Ctr::collinear_between;
  using Ctr::are_there_incident_constraints;
  using Ctr::make_hole;
  using Ctr::insert_constraint;
  using Ctr::locate;
  using Ctr::test_dim_down;
  using Ctr::fill_hole_delaunay;
  using Ctr::update_constraints;
  using Ctr::delete_vertex;
  using Ctr::push_back;
#endif
  typedef typename Geom_traits::Point_2  Point;
  Constrained_Delaunay_triangulation_2(const Geom_traits& gt=Geom_traits())
    : Ctr(gt) { }
  Constrained_Delaunay_triangulation_2(const CDt& cdt)
    : Ctr(cdt) {}
  Constrained_Delaunay_triangulation_2(List_constraints& lc,
    : Ctr(gt)
      typename List_constraints::iterator itc = lc.begin();
      for( ; itc != lc.end(); ++itc) {
	insert((*itc).first, (*itc).second);
      CGAL_triangulation_postcondition( is_valid() );
  template<class InputIterator>
  Constrained_Delaunay_triangulation_2(InputIterator it,
				       InputIterator last,
				       const Geom_traits& gt=Geom_traits() )
    : Ctr(gt)
      for ( ; it != last; it++) {
      	insert((*it).first, (*it).second);
  virtual ~Constrained_Delaunay_triangulation_2() {}
  // FLIPS
  bool is_flipable(Face_handle f, int i, bool perturb = true) const;
  void flip(Face_handle& f, int i);
  void flip_around(Vertex_handle va);
  void flip_around(List_vertices & new_vertices);
#ifndef CGAL_CDT2_USE_RECURSIVE_PROPAGATING_FLIP
  void non_recursive_propagating_flip(Face_handle f,int i);
  void propagating_flip(Face_handle f,int i, int depth=0);
#else
  void propagating_flip(Face_handle f,int i);
#endif
  void propagating_flip(List_edges & edges);
  // CONFLICTS
  bool test_conflict(Face_handle fh, const Point& p) const; //deprecated
  bool test_conflict(const Point& p, Face_handle fh) const;
  void find_conflicts(const Point& p, std::list<Edge>& le,  //deprecated
		      Face_handle hint= Face_handle()) const;
  //  //template member functions, declared and defined at the end
  // template <class OutputItFaces, class OutputItBoundaryEdges>
  // std::pair<OutputItFaces,OutputItBoundaryEdges>
  // get_conflicts_and_boundary(const Point  &p,
  // 		                OutputItFaces fit,
  // 		                OutputItBoundaryEdges eit,
  // 		                Face_handle start) const;
  // template <class OutputItFaces>
  // OutputItFaces
  // get_conflicts (const Point  &p,
  // 		    Face_handle start ) const;
  // template <class OutputItBoundaryEdges>
  // get_boundary_of_conflicts(const Point  &p,
  // INSERTION-REMOVAL
  Vertex_handle insert(const Point & a, Face_handle start = Face_handle());
  Vertex_handle insert(const Point& p,
		       Locate_type lt,
		       Face_handle loc, int li );
  Vertex_handle push_back(const Point& a);
//   template < class InputIterator >
//   std::ptrdiff_t insert(InputIterator first, InputIterator last);
  void remove(Vertex_handle v);
  void remove_incident_constraints(Vertex_handle v);
  void remove_constrained_edge(Face_handle f, int i);
//  OutputItFaces
//  remove_constrained_edge(Face_handle f, int i, OutputItFaces out)
  //for backward compatibility
  void insert(Point a, Point b) { insert_constraint(a, b);}
  void insert(Vertex_handle va, Vertex_handle  vb) {insert_constraint(va,vb);}
  void remove_constraint(Face_handle f, int i){remove_constrained_edge(f,i);}
  // CHECK
  bool is_valid(bool verbose = false, int level = 0) const;
protected:
  virtual Vertex_handle virtual_insert(const Point & a,
  virtual Vertex_handle virtual_insert(const Point& a,
				       Locate_type lt,
				       Face_handle loc,
				       int li );
//Vertex_handle special_insert_in_edge(const Point & a, Face_handle f, int i);
  void remove_2D(Vertex_handle v );
  virtual void triangulate_hole(List_faces& intersected_faces,
				List_edges& conflict_boundary_ab,
				List_edges& conflict_boundary_ba);
public:
  // MESHING
  // suppressed meshing functions from here
public:
#if defined(_MSC_VER)
  std::ptrdiff_t insert(InputIterator first, InputIterator last, int i = 0)
#else
#endif
      size_type n = number_of_vertices();
      std::vector<Point> points (first, last);
      spatial_sort (points.begin(), points.end(), geom_traits());
      Face_handle f;
      for (typename std::vector<Point>::const_iterator p = points.begin(), end = points.end();
              p != end; ++p)
          f = insert (*p, f)->face();
      return number_of_vertices() - n;
			     OutputItFaces fit,
			     Face_handle start = Face_handle()) const {
    CGAL_triangulation_precondition( dimension() == 2);
    int li;
    Locate_type lt;
    Face_handle fh = locate(p,lt,li, start);
    switch(lt) {
    case Ctr::OUTSIDE_AFFINE_HULL:
    case Ctr::VERTEX:
      return std::make_pair(fit,eit);
    case Ctr::FACE:
    case Ctr::EDGE:
    case Ctr::OUTSIDE_CONVEX_HULL:
      *fit++ = fh; //put fh in OutputItFaces
	pit = std::make_pair(fit,eit);
      pit = propagate_conflicts(p,fh,0,pit);
      pit = propagate_conflicts(p,fh,1,pit);
      pit = propagate_conflicts(p,fh,2,pit);
      return pit;
    CGAL_triangulation_assertion(false);
  OutputItFaces
		 OutputItFaces fit,
		 Face_handle start= Face_handle()) const {
    std::pair<OutputItFaces,Emptyset_iterator> pp =
      get_conflicts_and_boundary(p,fit,Emptyset_iterator(),start);
    return pp.first;
    std::pair<Emptyset_iterator, OutputItBoundaryEdges> pp =
      get_conflicts_and_boundary(p,Emptyset_iterator(),eit,start);
    return pp.second;
public:
// made  public for the need of Mesh_2
// but not documented
#ifdef CGAL_CDT2_USE_RECURSIVE_PROPAGATE_CONFLICTS
  propagate_conflicts (const Point  &p,
                      Face_handle fh,
                      int i,
     Face_handle fn = fh->neighbor(i);
     if ( fh->is_constrained(i) || ! test_conflict(p,fn)) {
       *(pit.second)++ = Edge(fn, fn->index(fh));
     } else {
       *(pit.first)++ = fn;
       int j = fn->index(fh);
       pit = propagate_conflicts(p,fn,ccw(j),pit);
       pit = propagate_conflicts(p,fn,cw(j), pit);
     return pit;
#else // NO CGAL_CDT2_USE_RECURSIVE_PROPAGATE_CONFLICTS
  non_recursive_propagate_conflicts (const Point  &p,
                                     Face_handle fh,
                                     int i,
    std::stack<std::pair<Face_handle, int> > stack;
    stack.push(std::make_pair(fh, i));
    while(!stack.empty()) {
      const Face_handle fh = stack.top().first;
      const int i = stack.top().second;
      stack.pop();
      const Face_handle fn = fh->neighbor(i);
      } else {
        stack.push(std::make_pair(fn, cw(j)));
        stack.push(std::make_pair(fn,ccw(j)));
    return pit;
                      Face_handle fh,
                      int i,
                      std::pair<OutputItFaces,OutputItBoundaryEdges>  pit,
                      int depth=0)  const
    if ( depth==100) return non_recursive_propagate_conflicts(p,fh,i,pit);
    } else {
      pit = propagate_conflicts(p,fn,ccw(j),pit,depth+1);
      pit = propagate_conflicts(p,fn,cw(j), pit,depth+1);
     return pit;
#endif // NO CGAL_CDT2_USE_RECURSIVE_PROPAGATE_CONFLICTS
public:
 OutputItFaces
 propagating_flip(List_edges & edges,
		  OutputItFaces out = Emptyset_iterator()) {
  // makes the triangulation Delaunay by flipping
  // List edges contains an initial list of edges to be flipped
  // Precondition : the output triangulation is Delaunay if the list
  // edges contains all edges of the input triangulation that need to be
  // flipped (plus possibly others)
  int i, ii, indf, indn;
  Face_handle ni, f,ff;
  Edge ei,eni;
  typename Ctr::Edge_set edge_set;
  Edge e[4];
  typename List_edges::iterator itedge=edges.begin();
  // initialization of the set of edges to be flip
  while (itedge != edges.end()) {
    f=(*itedge).first;
    i=(*itedge).second;
    if (is_flipable(f,i)) {
      eni=Edge(f->neighbor(i),this->mirror_index(f,i));
      if (less_edge(*itedge,eni)) edge_set.insert(*itedge);
      else edge_set.insert(eni);
    ++itedge;
  // flip edges and updates the set of edges to be flipped
  while (!(edge_set.empty())) {
    f=(*(edge_set.begin())).first;
    indf=(*(edge_set.begin())).second;
    // erase from edge_set the 4 edges of the wing of the edge to be
    // flipped (edge_set.begin) , i.e. the edges of the faces f and
    // f->neighbor(indf) that are distinct from the edge to be flipped
    ni = f->neighbor(indf);
    indn=this->mirror_index(f,indf);
    ei= Edge(f,indf);
    edge_set.erase(ei);
    e[0]= Edge(f,cw(indf));
    e[1]= Edge(f,ccw(indf));
    e[2]= Edge(ni,cw(indn));
    e[3]= Edge(ni,ccw(indn));
    for(i=0;i<4;i++) {
      ff=e[i].first;
      ii=e[i].second;
      eni=Edge(ff->neighbor(ii),this->mirror_index(ff,ii));
      if (less_edge(e[i],eni)) {edge_set.erase(e[i]);}
      else { edge_set.erase(eni);}
    // here is the flip
    *out++ = f;
    *out++ = f->neighbor(indf);
    flip(f, indf);
    //insert in edge_set the 4 edges of the wing of the edge that
    //have been flipped
    e[0]= Edge(f,indf);
    e[1]= Edge(f,cw(indf));
    e[2]= Edge(ni,indn);
    e[3]= Edge(ni,cw(indn));
    for(i=0;i<4;i++) {
      ff=e[i].first;
      ii=e[i].second;
      if (is_flipable(ff,ii)) {
	  edge_set.insert(e[i]);}
	else {
	  edge_set.insert(eni);}
  return out;
 OutputItFaces
 remove_constrained_edge(Face_handle f, int i, OutputItFaces out) {
  Ctr::remove_constrained_edge(f,i);
  if(dimension() == 2) {
    List_edges le;
    le.push_back(Edge(f,i));
    propagating_flip(le,out);
  return out;
template < class Gt, class Tds, class Itag >
bool
Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::
is_flipable(Face_handle f, int i, bool perturb /* = true */) const
  // determines if edge (f,i) can be flipped
  Face_handle ni = f->neighbor(i);
  if (is_infinite(f) || is_infinite(ni)) return false;
  if (f->is_constrained(i)) return false;
  return (side_of_oriented_circle(ni, f->vertex(i)->point(), perturb)
                                        == ON_POSITIVE_SIDE);
void
flip (Face_handle& f, int i)
  Face_handle g = f->neighbor(i);
  int j = this->mirror_index(f,i);
  // save wings neighbors to be able to restore contraint status
  Face_handle f1 = f->neighbor(cw(i));
  int i1 = this->mirror_index(f,cw(i));
  Face_handle f2 = f->neighbor(ccw(i));
  int i2 = this->mirror_index(f,ccw(i));
  Face_handle f3 = g->neighbor(cw(j));
  int i3 = this->mirror_index(g,cw(j));
  Face_handle f4 = g->neighbor(ccw(j));
  int i4 = this->mirror_index(g,ccw(j));
  // The following precondition prevents the test suit
  // of triangulation to work on constrained Delaunay triangulation
  //CGAL_triangulation_precondition(is_flipable(f,i));
  this->_tds.flip(f, i);
  // restore constraint status
  f->set_constraint(f->index(g), false);
  g->set_constraint(g->index(f), false);
  f1->neighbor(i1)->set_constraint(this->mirror_index(f1,i1),
				   f1->is_constrained(i1));
  f2->neighbor(i2)->set_constraint(this->mirror_index(f2,i2),
				   f2->is_constrained(i2));
  f3->neighbor(i3)->set_constraint(this->mirror_index(f3,i3),
				   f3->is_constrained(i3));
  f4->neighbor(i4)->set_constraint(this->mirror_index(f4,i4),
				   f4->is_constrained(i4));
  return;
void
  // makes the triangles incident to vertex va Delaunay using flips
  if (dimension() <= 1) return;
  Face_handle f=va->face();
  Face_handle next;
  Face_handle start(f);
  int i;
  do {
    i = f->index(va); // FRAGILE : DIM 1
    next = f->neighbor(ccw(i));  // turns ccw around a
    propagating_flip(f,i);
    f=next;
  } while(next != start);
void
flip_around(List_vertices& new_vertices)
  typename List_vertices::iterator itv=new_vertices.begin();
  for( ; itv != new_vertices.end(); itv++) {
    flip_around(*itv);
  return;
template <class Gt, class Tds, class Itag >
void
non_recursive_propagating_flip(Face_handle f , int i)
  std::stack<Edge> edges;
  const Vertex_handle& vp = f->vertex(i);
  edges.push(Edge(f,i));
  while(! edges.empty()){
    const Edge& e = edges.top();
    f = e.first;
    i = e.second;
    flip(f,i);
    if ( !is_flipable(f,i) ) edges.pop();
    i = ni->index(vp);
    if ( is_flipable(ni,i) ) edges.push( Edge(ni,i) );
void
propagating_flip(Face_handle f,int i, int depth)
  if (!is_flipable(f,i)) return;
#ifdef CGAL_CDT2_IMMEDIATELY_NON_RECURSIVE_PROPAGATING_FLIP
  non_recursive_propagating_flip(f,i);
#else
  int max_depth = 100;
  if(depth==max_depth){
    return;
  flip(f, i); // flip for constrained triangulations
  i = ni->index(f->vertex(i));
  propagating_flip(ni,i);
#endif
#else
void
// similar to the corresponding function in Delaunay_triangulation_2.h
#endif
 void
 propagating_flip(List_edges & edges) {
    propagating_flip(edges,Emptyset_iterator());
inline bool
  // true if point P lies inside the circle circumscribing face fh
  // return true  if P is inside the circumcircle of fh
  // if fh is infinite, return true when p is in the positive
  // halfspace or on the boundary and in the  finite edge of fh
  Oriented_side os = side_of_oriented_circle(fh,p,true);
  if (os == ON_POSITIVE_SIDE) return true;
  if (os == ON_ORIENTED_BOUNDARY && is_infinite(fh)) {
    int i = fh->index(infinite_vertex());
    return collinear_between(fh->vertex(cw(i))->point(), p,
			     fh->vertex(ccw(i))->point() );
  return false;
inline bool
  return test_conflict(p,fh);
void
find_conflicts(const Point& p, std::list<Edge>& le, Face_handle hint) const
  // sets in le the counterclocwise list of the edges of the boundary of the
  // union of the faces in conflict with p
  // an edge is represented by the incident face that is not in conflict with p
  get_boundary_of_conflicts(p, std::back_inserter(le), hint);
inline
typename Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::Vertex_handle
virtual_insert(const Point & a, Face_handle start)
  // virtual version of the insertion
  return insert(a,start);
inline
	       Locate_type lt,
	       Face_handle loc,
	       int li )
// virtual version of insert
  return insert(a,lt,loc,li);
inline
 // inserts a in the triangulation
// constrained edges are updated
// Delaunay property is restored
  Vertex_handle va= Ctr::insert(a, start);
  flip_around(va);
  return va;
insert(const Point& a, Locate_type lt, Face_handle loc, int li)
// insert a point p, whose localisation is known (lt, f, i)
  Vertex_handle va= Ctr::insert(a,lt,loc,li);
  flip_around(va);
  return va;
inline
push_back(const Point &p)
  return insert(p);
void
  List_edges new_edges;
  Ctr::triangulate_hole(intersected_faces,
		       conflict_boundary_ba,
		       new_edges);
  propagating_flip(new_edges);
  return;
inline void
  // remove a vertex and updates the constrained edges of the new faces
  // precondition : there is no incident constraints
  CGAL_triangulation_precondition( v != Vertex_handle() );
  CGAL_triangulation_precondition( ! is_infinite(v));
  CGAL_triangulation_precondition( ! are_there_incident_constraints(v));
  if  (dimension() <= 1)    Ctr::remove(v);
  else  remove_2D(v);
  return;
// template < class Gt, class Tds, class Itag >
// typename
// Constrained_Delaunay_triangulation_2<Gt,Tds,Itag>::Vertex_handle
// special_insert_in_edge(const Point & a, Face_handle f, int i)
//   // insert  point p in edge(f,i)
//   // bypass the precondition for point a to be in edge(f,i)
//   // update constrained status
//   // this member fonction is not robust with exact predicates
//   // and approximate construction. Should be removed
//   Vertex_handle vh=Ctr::special_insert_in_edge(a,f,i);
//   flip_around(vh);
//   return vh;
void
remove_2D(Vertex_handle v)
 if (test_dim_down(v)) {  this->_tds.remove_dim_down(v);  }
  else {
     std::list<Edge> hole;
    make_hole(v, hole);
    std::list<Edge> shell=hole; //because hole will be emptied by fill_hole
    fill_hole_delaunay(hole);
    update_constraints(shell);
    delete_vertex(v);
  return;
void
   List_edges iconstraints;
   if (are_there_incident_constraints(v,
				      std::back_inserter(iconstraints))) {
     Ctr::remove_incident_constraints(v);
     if (dimension()==2) propagating_flip(iconstraints);
   return;
void
  remove_constrained_edge(f,i,Emptyset_iterator());
  return;
bool
is_valid(bool verbose, int level) const
  bool result = Ctr::is_valid(verbose, level);
  CGAL_triangulation_assertion( result );
    Finite_faces_iterator fit= finite_faces_begin();
    for (; fit != finite_faces_end(); fit++) {
      for(int i=0;i<3;i++) {
	result = result && !is_flipable(fit,i, false);
    return result;
} //namespace CGAL
#endif // CGAL_CONSTRAINED_DELAUNAY_TRIANGULATION_2_H
