- To:
- Subject: Re: [cgal-discuss] use CGAL as the grid generator
- Date: Mon, 07 Jan 2013 08:20:47 +0100
Can you be more precise on what you need?
On 01/05/2013 02:25 AM,
wrote:
Dear friends:
I want to develop a numerical simulation package for convection heat
transfer in 2-D domain with finite volume method. I want to use CGAL as the
grid generator. The computational domain is composed of by line , arc , etc.
Could you please tell me which package of CGAL should i started from.
I just installed it successfully in opensuse 12.1.
Regards
- [cgal-discuss] use CGAL as the grid generator, ztdep, 01/05/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Sebastien Loriot (GeometryFactory), 01/07/2013
- 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- Re: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- 回复: 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: 回复: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
