- To:
- Subject: Re: [cgal-discuss] Return Nearest Neighbor Index
- Date: Thu, 24 Jan 2013 10:22:41 +0100
Go at [1], and I think the second example (Using an Integer as Key
Type) is doing what you.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_61.3.6
On 01/24/2013 09:55 AM, Rhys D wrote:
Hi,
Now that I am up and running with CGAL, I am dismayed to discover that
the nearest neighbor search does not allow you to return an index.
I found an old post from 2007 from Johannes that suggests that he has a
working implementation of a nearest neighbor search that will return an
index.
Failing that, does anyone else have any ideas?
Rhys.
- [cgal-discuss] Return Nearest Neighbor Index, Rhys D, 01/24/2013
- Re: [cgal-discuss] Return Nearest Neighbor Index, Sebastien Loriot (GeometryFactory), 01/24/2013
- Re: [cgal-discuss] Return Nearest Neighbor Index, Rhys D, 01/24/2013
- Message not available
- [cgal-discuss] Return Nearest Neighbor Index, Ashish Upadhyay, 01/24/2013
