- To:
- Subject: Re: [cgal-discuss] Return Nearest Neighbor Index
- Date: Thu, 24 Jan 2013 13:01:54 +0100
Please start a new thread for an unrelated question.
Your log is telling you to install GMP:
> -- Could NOT find GMP (missing: GMP_LIBRARIES GMP_INCLUDE_DIR)
> CMake Error at cmake/modules/CGAL_SetupDependencies.cmake:66 (message):
> CGAL requires GMP to be found
> Call Stack (most recent call first):
> CMakeLists.txt:590 (include)
Sebastien.
On 01/24/2013 12:58 PM, Ashish Upadhyay wrote:
Dear Group Members
I am trying to install CGAL as root and getting following message. I am
not much informed about linux (I am using latest Fedora). Can you please
help in this?
[root@localhost CGAL-4.1]# /root/cmake-2.8.10.2/bin/./cmake /root/CGAL-4.1
-- The CXX compiler identification is GNU 4.1.2
-- The C compiler identification is GNU 4.1.2
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
== Setting paths ==
-- Build CGAL from release in directory CGAL-4.1
-- Packagenames: CGAL-4.1
== Setting paths (DONE) ==
== Generate version files ==
-- CGAL_MAJOR_VERSION=4
-- CGAL_MINOR_VERSION=1
-- CGAL_BUGFIX_VERSION=0
-- CGAL_SONAME_VERSION=10
-- CGAL_SOVERSION =10.0.0
-- CGAL_REFERENCE_CACHE_DIR=
-- Building shared libraries
-- Targetting Unix Makefiles
-- Using /usr/bin/c++ compiler.
-- USING CMake version: 2.8.10
-- System: Linux
-- USING GCC_VERSION = '4.1.2 20070626 (Red Hat 4.1.2-14)'
-- Using gcc version 4 or later. Adding -frounding-math
== Generate version files (DONE) ==
== Set up flags ==
-- Build type: Release
-- USING CXXFLAGS = ' -frounding-math -O3 -DNDEBUG'
-- USING LDFLAGS = ' '
== Set up flags (DONE) ==
== Detect external libraries ==
-- External libraries supported:
GMP;GMPXX;MPFR;ZLIB;OpenGL;LEDA;MPFI;RS;RS3;OpenNL;TAUCS;Eigen3;BLAS;LAPACK;QGLViewer;ESBTL;Coin3D;NTL;IPE
-- Preconfiguring library: GMP ...
-- Configuring incomplete, errors occurred!
Thanks
Ashish
On 24 January 2013 14:52, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Go at [1], and I think the second example (Using an Integer as Key
Type) is doing what you.
Sebastien.
[1]
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Spatial_searching/Chapter___main.html#Subsection_61.3.6
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Spatial_searching/Chapter_main.html#Subsection_61.3.6>
On 01/24/2013 09:55 AM, Rhys D wrote:
Hi,
Now that I am up and running with CGAL, I am dismayed to
discover that
the nearest neighbor search does not allow you to return an index.
I found an old post from 2007 from Johannes that suggests that
he has a
working implementation of a nearest neighbor search that will
return an
index.
Failing that, does anyone else have any ideas?
Rhys.
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
- [cgal-discuss] Return Nearest Neighbor Index, Rhys D, 01/24/2013
- Re: [cgal-discuss] Return Nearest Neighbor Index, Sebastien Loriot (GeometryFactory), 01/24/2013
- Re: [cgal-discuss] Return Nearest Neighbor Index, Rhys D, 01/24/2013
- Message not available
- [cgal-discuss] Return Nearest Neighbor Index, Ashish Upadhyay, 01/24/2013
