- To:
- Subject: Re: [cgal-discuss] ccw when triangulation is modified
- Date: Tue, 29 Jan 2013 15:00:18 +0100
On 01/29/2013 01:25 PM, Vero wrote:
Dear Sebastien,You will find in [1] what is expected for the triangulation data structure to be valid.
If by making the triangulation invalid you mean that I may get a non
planar graph with overlapped triangles, my own code is trying to handle
that, in part with the springs, but to do it properly I have been making
some assumptions about the way ccw and cw work... concretely I had
thought that they would return the next vertex as it would have been
when the triangulation was created. But, if by "making the
triangulation invalid" you mean that these kind of operations will not
behave consistently any more, I suppose I will have to look for another
solution.
cw_v and ccw_v are simply combinatorial (there are no predicate involved). You may need to use an orientation predicate
Unfortunately move doesn't help, because, as I understood
from the documentation, it modifies the triangulation, that would mess
around the springs and the constants that had been assigned to them may
no longer work. Or did I understood wrong what the documentation means?
If by the "it modifies the triangulation" you mean that the Delaunay property is preserved while moving vertices then yes. However, the information associated to vertices will not change (only that of the faces created/destroyed)
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/TDS_2/Chapter_main.html#Subsection_38.1.1
[2] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Kernel_23_ref/Function_orientation.html
Thanks a lot.
On 28 January 2013 12:25, Sebastien Loriot (GeometryFactory)
<mailto:>>
wrote:
Modifying the triangulation using vh->set_point(newPoint) does not
modify the combinatorial structure of the triangulation and can
make the triangulation invalid.
You need to use the move function instead: t.move(vh,newPoint).
Sebastien.
On 01/28/2013 12:33 PM, Vero wrote:
Dear members,
I have been using the Constrained_Delaunay___triangulation_2 for a
mass-spring model. However, I am getting somewhat worried that
when the
triangles get flipped, the behaviour of ccw and cw may not be
returning
the vertices according to their original orientation, but
according to
their current orientation. I had supposed the opposite. Could you
please give me some help here? To set the new coordinate of the
vertices I have been using vh->set_point(newPoint).
Thanks,
Veronica E. Arriola
Room G5 Chemistry West,
School of Computer Science
University of Birmingham
http://www.cs.bham.ac.uk/~__vxa855/
<http://www.cs.bham.ac.uk/~vxa855/>
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
Veronica E. Arriola
- [cgal-discuss] ccw when triangulation is modified, Vero, 01/28/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Sebastien Loriot (GeometryFactory), 01/28/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Vero, 01/29/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Sebastien Loriot (GeometryFactory), 01/29/2013
