- To:
- Subject: Re: [cgal-discuss] ccw when triangulation is modified
- Date: Tue, 29 Jan 2013 12:25:14 +0000
Dear Sebastien,
If by making the triangulation invalid you mean that I may get a non planar graph with overlapped triangles, my own code is trying to handle that, in part with the springs, but to do it properly I have been making some assumptions about the way ccw and cw work... concretely I had thought that they would return the next vertex as it would have been when the triangulation was created. But, if by "making the triangulation invalid" you mean that these kind of operations will not behave consistently any more, I suppose I will have to look for another solution. Unfortunately move doesn't help, because, as I understood from the documentation, it modifies the triangulation, that would mess around the springs and the constants that had been assigned to them may no longer work. Or did I understood wrong what the documentation means?
Thanks a lot.
On 28 January 2013 12:25, Sebastien Loriot (GeometryFactory) <> wrote:
Modifying the triangulation using vh->set_point(newPoint) does not
modify the combinatorial structure of the triangulation and can
make the triangulation invalid.
You need to use the move function instead: t.move(vh,newPoint).
Sebastien.--
On 01/28/2013 12:33 PM, Vero wrote:
Dear members,
I have been using the Constrained_Delaunay_triangulation_2 for a
mass-spring model. However, I am getting somewhat worried that when the
triangles get flipped, the behaviour of ccw and cw may not be returning
the vertices according to their original orientation, but according to
their current orientation. I had supposed the opposite. Could you
please give me some help here? To set the new coordinate of the
vertices I have been using vh->set_point(newPoint).
Thanks,
Veronica E. Arriola
Room G5 Chemistry West,
School of Computer Science
University of Birmingham
http://www.cs.bham.ac.uk/~vxa855/
Veronica E. Arriola
- [cgal-discuss] ccw when triangulation is modified, Vero, 01/28/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Sebastien Loriot (GeometryFactory), 01/28/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Vero, 01/29/2013
- Re: [cgal-discuss] ccw when triangulation is modified, Sebastien Loriot (GeometryFactory), 01/29/2013
