- To: "" <>
- Subject: Re: [cgal-discuss] CGAL demos on Windows won't configure
- Date: Thu, 31 Jan 2013 09:04:39 +0100
Le mercredi 30 janvier 2013 16:23:22 Jeffrey Bush a écrit :
> Hi,
> When trying to build the CGAL demos CMAKE fails. If doing everything
> besides the demos (core, ImageIO, examples) it works fine. Not all of the
> demos cause errors, but most (~25 do). They all seem to be about not being
> able to access certain paths, which are paths that are like C:/.../C:/.../
> - notice it trying to re-root itself there? It shouldn't be doing that.
> Running with CMAKE_USE_RELATIVE_PATHS does not help.
> An example error message that is shown here and the entire cmake log is
> attached.
> == Generating build files for demos ==
> -- Configuring demo in demo/C:/Program Files (x86)/CGAL-4.1/demo/AABB_tree
> Requested component: Qt4
> Requested component: MPFR
> Requested component: GMP
> Found QGLViewer:
> C:/Qt/libQGLViewer-2.3.17/QGLViewer/release64/QGLViewer2.lib
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:111 (file):
> file Internal CMake error when trying to open file: C:/Program Files
> (x86)/CGAL-4.1/demo/C:/Program Files
> (x86)/CGAL-4.1/demo/AABB_tree/MainWindow_moc.cpp_parameters for writing.
Do not use a sub-directory of "C:\Program Files (x86)" as binary directory
for
CMake. That causes a bug in Qt4 CMake macros.
Anyway, you should compile CGAL in your user directory, and not in the system
directory "C:\Program Files (x86)". Note that you can at the end, *install*
the compiled CGAL libraries there.
Laurent Rineau, PhD
- [cgal-discuss] CGAL demos on Windows won't configure, Jeffrey Bush, 01/31/2013
- [cgal-discuss] Re: CGAL demos on Windows won't configure, Jeffrey Bush, 01/31/2013
- Re: [cgal-discuss] CGAL demos on Windows won't configure, Laurent Rineau (CGAL/GeometryFactory), 01/31/2013
- Re: [cgal-discuss] CGAL demos on Windows won't configure, Jeffrey Bush, 01/31/2013
- Re: [cgal-discuss] CGAL demos on Windows won't configure, Andreas Fabri, 01/31/2013
- Re: [cgal-discuss] CGAL demos on Windows won't configure, Philipp Moeller, 01/31/2013
- Re: Re: [cgal-discuss] CGAL demos on Windows won't configure, Laurent Rineau (CGAL/GeometryFactory), 01/31/2013
