cgal-discuss - Re: [cgal-discuss] CGAL demos on Windows won't configure
  • To: "" <>
  • Subject: Re: [cgal-discuss] CGAL demos on Windows won't configure
  • Date: Thu, 31 Jan 2013 00:43:04 -0800
Thanks. However, just so you know, the CGAL installer installs to Program Files (x86) on Windows x64.
I ended up getting around it by building just the examples and demos I wanted. However in the process of building all of this I have identified more problems. The boost libraries are not added to the import list in the resulting project, only the include directories are added. Each project needs to have the boot libraries manually entered. The CMAKE GUI shows the boost libraries it will add, with all the right path information, however these don't end up in the resulting VS project.
Thanks again - although I am still having problems getting things to work just right, it kind of makes sense that a library as massive as this takes time to even get it going.
Jeff
On Thu, Jan 31, 2013 at 12:04 AM, Laurent Rineau (CGAL/GeometryFactory) <> wrote:
Le mercredi 30 janvier 2013 16:23:22 Jeffrey Bush a écrit :
> Hi,
> When trying to build the CGAL demos CMAKE fails. If doing everything
> besides the demos (core, ImageIO, examples) it works fine. Not all of the
> demos cause errors, but most (~25 do). They all seem to be about not being
> able to access certain paths, which are paths that are like C:/.../C:/.../
> - notice it trying to re-root itself there? It shouldn't be doing that.
> Running with CMAKE_USE_RELATIVE_PATHS does not help.
> An example error message that is shown here and the entire cmake log is
> attached.
> == Generating build files for demos ==
> -- Configuring demo in demo/C:/Program Files (x86)/CGAL-4.1/demo/AABB_tree
> Requested component: Qt4
> Requested component: MPFR
> Requested component: GMP
> Found QGLViewer:
> C:/Qt/libQGLViewer-2.3.17/QGLViewer/release64/QGLViewer2.lib
> CMake Error at C:/Program Files (x86)/CMake
> 2.8/share/cmake-2.8/Modules/Qt4Macros.cmake:111 (file):
> file Internal CMake error when trying to open file: C:/Program Files
> (x86)/CGAL-4.1/demo/C:/Program Files
> (x86)/CGAL-4.1/demo/AABB_tree/MainWindow_moc.cpp_parameters for writing.
Do not use a sub-directory of "C:\Program Files (x86)" as binary directory for
CMake. That causes a bug in Qt4 CMake macros.
Anyway, you should compile CGAL in your user directory, and not in the system
directory "C:\Program Files (x86)". Note that you can at the end, *install*
the compiled CGAL libraries there.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
