cgal-discuss - Re: Re: [cgal-discuss] running a demo on ubuntu Linux
  • To:
  • Subject: Re: Re: [cgal-discuss] running a demo on ubuntu Linux
  • Date: Thu, 31 Jan 2013 14:54:55 +0100
Le mercredi 30 janvier 2013 09:20:54 sara ershadi a écrit :
> Dear Laurent ,
> Hi ,
> I have another question too .
> 3- I have installed "libcgal-dev" and "libcgal-demo" and "libcgal-ipelets"
> and "libcgal7"
> too . If I want to run demo what should I do and If I want to run demo in
> situation from source
> CGAL files I should to remove all this 4 software or remove "libcgal-dev"
> lonely is enough.
As you want. Removing libcgal-dev and libcgal7 should also remove all the one
that depend on them.
Actually, you do not really have to remove them from your system. You can
compile a different version of CGAL from sources. Be careful, if you want to
compile a demo depending on CGAL, to fill the CMake variable "CGAL_DIR" with
the directory where you have built CGAL from sources.
> what is my demo file now ?
Sorry, I do not understand the question.
Laurent Rineau, PhD
