cgal-discuss - Re: [cgal-discuss] running a demo on ubuntu Linux
  • To:
  • Subject: Re: [cgal-discuss] running a demo on ubuntu Linux
  • Date: Tue, 29 Jan 2013 10:38:33 +0100
Le mardi 29 janvier 2013 00:05:08 sara a écrit :
> Hi all,
> I am working with ubuntu Linux. since it seems the speed of CGAL is more in
> linux than windows.
> I have installed Libcgal 3 item from software center in ubuntu
> but when I want to run a demo it dosn't cmake . properly . the error was :
> -- NOTICE: This demo requires CGAL and Qt3, and will not be compiled.
> then I decide to make the CGAL from source . I have downloaded
> CGAL-4.1.tar.gz from CGAL website.
> *1- the folder auxiliary\gmp\include is empty ! I expect it contain the
> needed gmp and mpfr.h files !*
> I egnore it and continue to build the CGAL Library.
> cd
> cd CGAL-4.1
> cmake .
> then I saw that qt3 and qt4 are others required lib are installed properly
> in output appeared in terminal .
> make
> and then I was sure that this time CGAL installed properly certainly. then I
> decide to run Mesh_2 demo
> cd CGAL-4.1
> cd demo
> cd Mesh_2
> mkdir build
> cd build
> cmake ..
> and unfortunately this message appeared :
Install the package named "libcgal-dev". It will install a lot of
dependencies
of CGAL:
libboost-dev
Boost C++ Libraries development files (default version)
libboost-graph-dev
generic graph components and algorithms in C++ (default version)
libboost-program-options-dev
program options library for C++ (default version)
libboost-thread-dev
portable C++ multi-threading (default version)
libgmp3-dev
Multiprecision arithmetic library developers tools
libmpfr-dev
multiple precision floating-point computation developers tools
libqt3-mt-dev
Qt development files (Threaded)
libqt4-dev
Qt 4 development files
zlib1g-dev
compression library - development
Source: http://packages.ubuntu.com/lucid/libcgal-dev
After you have installed libcgal-dev, if you want to compile it from sources,
remove the packages libcgal and libcgal-dev from your system, and compile
from
CGAL sources. All the main dependencies of CGAL should remain installed.
Laurent Rineau, PhD
