cgal-discuss - Re: [cgal-discuss] Problem after installation
  • To: NMoreau <>
  • Cc:
  • Subject: Re: [cgal-discuss] Problem after installation
  • Date: Tue, 05 Feb 2013 13:20:43 +0100
NMoreau
writes:
> I never used CGAL before, and was trying to use its half-edge Polyhedron
> structure for the need of a project. I installed the library on my Ubuntu
> system using cmake. So far, no problem detected.
> So the problem is here: I tried to compile my code. There is nothing in my
> own code that seems to disturb the compiler... But I have some issues with
> the library that I just do not understand. Here is the error message... I
> don't know if this will be enough for someone to understand from where this
> problem comes but as I have no idea why I get this message, I don't know
> what kind of other information would be relevant in order to fix this...
Can you please post the output of gcc --version and a small sample
program that reproduces the error? Which files do you include and what
parts of CGAL do you use?
[...snipped error output...]
