- To:
- Subject: Re: [cgal-discuss] Problem after installation
- Date: Tue, 05 Feb 2013 13:57:16 +0100
Le mardi 05 février 2013 03:27:45 NMoreau a écrit :
> Hello,
> I never used CGAL before, and was trying to use its half-edge Polyhedron
> structure for the need of a project. I installed the library on my Ubuntu
> system using cmake. So far, no problem detected.
> So the problem is here: I tried to compile my code. There is nothing in my
> own code that seems to disturb the compiler... But I have some issues with
> the library that I just do not understand. Here is the error message... I
> don't know if this will be enough for someone to understand from where this
> problem comes but as I have no idea why I get this message, I don't know
> what kind of other information would be relevant in order to fix this...
> Thank you very much!
> $ make
> g++ -o Appli *.cpp -lGL -lGLU -lglut -L/usr/local/lib -lCGAL -lgsl
> -lgslcblas -lm
> In file included from /usr/local/include/CGAL/Uncertain.h:25:0,
> from /usr/local/include/CGAL/assertions.h:333,
> from /usr/local/include/CGAL/basic.h:42,
> from /usr/local/include/CGAL/Cartesian/Cartesian_base.h:28,
> from /usr/local/include/CGAL/Simple_cartesian.h:28,
> from MeshBuilder.h:19,
> from Mesh.h:32,
> from useful.h:20,
> from Aide_Affichage.cpp:4:
> /usr/local/include/CGAL/enum.h:37:5: erreur: expected identifier before ‘-’
> token
It seems that, somewhere in your own code, you have a macro definition of
"NEGATIVE". That perturbs the code in <CGAL/enum.h>.
Laurent Rineau, PhD
- [cgal-discuss] Problem after installation, NMoreau, 02/05/2013
- Re: [cgal-discuss] Problem after installation, Philipp Moeller, 02/05/2013
- Re: [cgal-discuss] Problem after installation, Laurent Rineau (CGAL/GeometryFactory), 02/05/2013
- [cgal-discuss] Re: Problem after installation, NMoreau, 02/05/2013
