cgal-discuss - [cgal-discuss] Re: Minkowski_sum_3 memory leak?
  • To:
  • Subject: [cgal-discuss] Re: Minkowski_sum_3 memory leak?
  • Date: Thu, 7 Feb 2013 02:59:50 -0800 (PST)
The same problem is present using CGAL::Cartesian<CGAL::Gmpq>.
2013/2/7 Philipp Moeller-2 [via cgal-discuss] <[hidden email]>
mastair <[hidden email]> writes:
> So apparently the problem is with BOOST_PP_REPEAT_FROM_TO(1, 9,
> CGAL_CONSTRUCTION_OPERATOR, _) on line 1381 of lazy.h.
That simply expands to a bunch of overloaded operator(). The new'd
pointer is handed off to a ref-counted class.
> Any idea?
It's not clear to me if Lazy leaks or the constructor wrapped by
Lazy. It would be a good try to run the program with a non-lazy exact
kernel and see if the checker comes up with the same problem.
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Minkowski-sum-3-memory-leak-tp4656672p4656677.html
To unsubscribe from Minkowski_sum_3 memory leak?, click here.
NAML
View this message in context: Re: Minkowski_sum_3 memory leak?
