[cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?
- To: "" <>
- Subject: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?
- Date: Thu, 7 Feb 2013 15:31:03 -0800
Hi,
I am using AABB_tree to determine intersections between a plane (call it "h") and a polyhedron, resulting in a vector of segments ("segs"). However the following test fails:
h.has_on(*segs.begin())
This shouldn't be. However doing research I realized the result may be because of using Cartesian instead of Exact_predicates_inexact_constructions_kernel, so I switched to that. But still the same problem!
Running the debugger I get to this function:
inline
Uncertain<Sign>
sign (const Interval_nt<Protected> & d)
if (d.inf() > 0.0) return POSITIVE;
if (d.sup() < 0.0) return NEGATIVE;
if (d.inf() == d.sup()) return ZERO;
return Uncertain<Sign>::indeterminate();
With the following value for d:d = {
_inf=5.6843418860808015e-014,
_sup=5.6843418860808015e-014,
tester={...}
It seems as though the d.inf() == d.sup() check should be first? It seems that if sup <= inf and inf > 0 or sup < 0, then the d.inf() == d.sup() can only be 0 == 0... (but I guess sup > inf - I don't understand exactly what this is all about).
Just for scale, my points have values on the order of 2500 and the plane is <0,0,1> -300.
If this is right (and I could easily be, I don't know too much about double-precision mathematical testing), then what am I doing wrong? My meshes are LARGE so I don't want to use the infinite-precision numbers.
Thanks!
Jeff
- [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Jeffrey Bush, 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Sebastien Loriot (GeometryFactory), 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Jeffrey Bush, 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Sebastien Loriot (GeometryFactory), 02/11/2013
- Re: Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
