Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?
- To:
- Subject: Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?
- Date: Fri, 08 Feb 2013 06:59:07 +0100
Check this FAQ entry:
http://www.cgal.org/FAQ.html#inexact_NT
If you use Exact_predicates_exact_constructions_kernel.h this should be OK.
Even if it's not documented and not officially supported, I suggest you to have a look at the file CGAL/intersection_of_Polyhedra_3.h
where the following function is defined:
template <typename Polyhedron, typename OutputIterator>
OutputIterator
intersection_Polyhedron_3_Polyhedron_3(const Polyhedron& P, const Polyhedron& Q, OutputIterator out)
where OutputIterator accepts std::vector<typename Kernel::Point_3> objects (to represent a polyline).
A plane can always be represented by a triangulated quad.
Sebastien.
On 02/08/2013 12:31 AM, Jeffrey Bush wrote:
Hi,
I am using AABB_tree to determine intersections between a plane (call it
"h") and a polyhedron, resulting in a vector of segments ("segs").
However the following test fails:
h.has_on(*segs.begin())
This shouldn't be. However doing research I realized the result may be
because of using Cartesian instead of
Exact_predicates_inexact_constructions_kernel, so I switched to that.
But still the same problem!
Running the debugger I get to this function:
inline
Uncertain<Sign>
sign (const Interval_nt<Protected> & d)
if (d.inf()> 0.0)return POSITIVE;
if (d.sup()< 0.0)return NEGATIVE;
if (d.inf() == d.sup())return ZERO;
return Uncertain<Sign>::indeterminate();
With the following value for d:
d = {
_inf=5.6843418860808015e-014,
_sup=5.6843418860808015e-014,
tester={...}
It seems as though the d.inf() == d.sup() check should be first? It
seems that if sup <= inf and inf > 0 or sup < 0, then the d.inf() ==
d.sup() can only be 0 == 0... (but I guess sup > inf - I don't
understand exactly what this is all about).
Just for scale, my points have values on the order of 2500 and the plane
is <0,0,1> -300.
If this is right (and I could easily be, I don't know too much about
double-precision mathematical testing), then what am I doing wrong? My
meshes are LARGE so I don't want to use the infinite-precision numbers.
Thanks!
Jeff
- [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Jeffrey Bush, 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Sebastien Loriot (GeometryFactory), 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Jeffrey Bush, 02/08/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Sebastien Loriot (GeometryFactory), 02/11/2013
- Re: Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
- Re: [cgal-discuss] Exact_predicates_inexact_constructions_kernel - sign checks are in the wrong order?, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
