cgal-discuss - Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: Re: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Sat, 09 Feb 2013 16:22:41 +0100
I think the problems comes from my fix. Could you try this:
--- a/include/CGAL/Intersections_3/intersection_3_1_impl.h
+++ b/include/CGAL/Intersections_3/intersection_3_1_impl.h
@@ -57,7 +57,7 @@ intersection(const typename K::Plane_3 &plane,
return Object();
- return make_object(k.construct_plane_3_object()(
+ return make_object(k.construct_point_3_object()(
den*line_pt.hx()-num*line_dir.dx(),
den*line_pt.hy()-num*line_dir.dy(),
den*line_pt.hz()-num*line_dir.dz(),
Sebastien.
On 02/08/2013 12:38 PM, jeanbaptiste lespiau wrote:
Thank you for this very fast response.
I have replaced the headers directly in CGAL.
Now "CGAL::make_skin_surface_mesh_3(p, l.begin(), l.end(),
shrinkfactor);" completly works :)
CGAL::subdivide_skin_surface_mesh_3(skin_surface, p); compiles without
errors. However, when launched it raises an invalid assertion:
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
File: /usr/local/include/CGAL/Skin_surface_base_3.h
Line: 484
Explanation: intersection: no intersection.
Since I have applied subdivide on a theorically valid skin surface
(created by mesh_skin_surface_3), I think this is still not normal.
Thank you for your help.
2013/2/8 Sebastien Loriot (GeometryFactory)
<mailto:>>
Attached to this email, you'll find patched header files than need to be
used instead of those from CGAL (you can edit your CMakeLists.txt and
add the patch to this directory include_directories(BEFORE XXX) )
Let us know if this solves your problem.
Sebastien.
On 02/04/2013 11:12 PM, J-B wrote:
Hello,
I am using the CGAL example Skin_surface_3 /
skin_surface_pdb_reader.cpp to
build a skin surface from an .pdb file.
It works (of course, the example does), but when I try to use other
functions I found at
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Skin_surface_3/Chapter_main.__html
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Skin_surface_3/Chapter_main.html>
awfull errors arrive.
In particular, it is about the two
functions:CGAL::make_skin___surface_mesh_3(p, l.begin(), l.end(),
shrinkfactor); (does 2 actions in
1)andCGAL::subdivide_skin___surface_mesh_3(skin_surface, p);
I think it is because ESBTL defines it owns Kernel (typedef
ESBTL::CGAL::EPIC_kernel_with___atom K;) while CGAL uses typedef
CGAL::Exact_predicates___inexact_constructions_kernel K, but
ESBTL doesn't
work if I uses the last typedef.
I put an example here :
https://github.com/Gueust/__Pymol-Tunnels-Cavities-Finder/__blob/master/Example.tar.gz
<https://github.com/Gueust/Pymol-Tunnels-Cavities-Finder/blob/master/Example.tar.gz>
using the smaller code possible with one line that creates the
errors.
To make it compile, if you have both ESBTL and CGAL you only
need to go to
build/ and do cmake .
It may be as simple as modifying a typedef, but being not
skilled with those
libraries I am completely lost. If someone has the answer it
could be great.
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.__nabble.com/Use-of-ESBTL-and-__Skin-Surface-create-errors-__tp4656653.html
<http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653.html>
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
