cgal-discuss - [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • To:
  • Subject: [cgal-discuss] Use of ESBTL and Skin Surface create errors
  • Date: Mon, 4 Feb 2013 14:12:56 -0800 (PST)
Hello,
I am using the CGAL example Skin_surface_3 / skin_surface_pdb_reader.cpp to
build a skin surface from an .pdb file.
It works (of course, the example does), but when I try to use other
functions I found at
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Skin_surface_3/Chapter_main.html
awfull errors arrive.
In particular, it is about the two
functions:CGAL::make_skin_surface_mesh_3(p, l.begin(), l.end(),
shrinkfactor); (does 2 actions in
1)andCGAL::subdivide_skin_surface_mesh_3(skin_surface, p);
I think it is because ESBTL defines it owns Kernel (typedef
ESBTL::CGAL::EPIC_kernel_with_atom K;) while CGAL uses typedef
CGAL::Exact_predicates_inexact_constructions_kernel K, but ESBTL doesn't
work if I uses the last typedef.
I put an example here :
https://github.com/Gueust/Pymol-Tunnels-Cavities-Finder/blob/master/Example.tar.gz
using the smaller code possible with one line that creates the errors.
To make it compile, if you have both ESBTL and CGAL you only need to go to
build/ and do cmake .
It may be as simple as modifying a typedef, but being not skilled with those
libraries I am completely lost. If someone has the answer it could be great.
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Use-of-ESBTL-and-Skin-Surface-create-errors-tp4656653.html
