cgal-discuss - RE: [cgal-discuss] Extended polyhedra & nef_polyhedra
  • To: "" <>
  • Subject: RE: [cgal-discuss] Extended polyhedra & nef_polyhedra
  • Date: Fri, 15 Feb 2013 07:53:41 +0000
  • Accept-language: en-GB, en-US
Hello,
My CItemsEx is the following code below. It's actually based on one of the
provided examples. However, I found in one of the demos that there is a
function to calculate normals for polyhedra. If there is no other way then I
guess I can use this one and store all my other attributes in a wrapper class
which will then contain the actual geometry solid as a member.
struct CItemsEx : public CGAL::Polyhedron_items_3
// A redefined items class for the Polyhedron_3 with a refined vertex class
that contains a
// member for the normal vector and a refined facet with a normal vector
instead of the
// plane equation (this is an alternative solution instead of using
// Polyhedron_traits_with_normals_3).
// wrap vertex
template <class Refs, class Traits>
struct Vertex_wrapper
typedef typename Traits::Point_3 Point;
typedef typename Traits::Vector_3 Normal;
typedef CVertexEx<Refs,
CGAL::Tag_true,
Point,
Normal> Vertex;
// wrap face
struct Face_wrapper
typedef CFacetEx<Refs,
CGAL::Tag_true,
Point,
Normal> Face;
// wrap halfedge
struct Halfedge_wrapper
typedef CHalfeEdgeEx<Refs,
CGAL::Tag_true,
CGAL::Tag_true,
CGAL::Tag_true,
Normal> Halfedge;
Thanks a lot
Chris
Chris Theis
CERN/DGS-RP - European Organization for Nuclear Research
1211 Geneva 23, Switzerland
Phone: +41 22 767 8069                    Office: 892-2A-015
e-mail:
           www: http://www.cern.ch/theis
-----Original Message-----
[mailto:]
On Behalf Of Sebastien Loriot (GeometryFactory)
Sent: 15 February 2013 07:09
To:
Subject: Re: [cgal-discuss] Extended polyhedra & nef_polyhedra
On 02/14/2013 05:14 PM, Chris Theis wrote:
> Hi Sebastien,
> my problem actually starts when I do the following:
> CGAL::Polyhedron_3<Kernel,CItemsEx> TestPoly;
> // CItemsEx is derived from Polyhedron_items_3 and extends vertices,
> faces& halfedges
> CGAL::Nef_polyhedron_3<Kernel> TestSolid( TestPoly );
> as long as I use
> CGAL::Polyhedron_3<Kernel, CGAL::Polyhedron_items_3> TestPoly;
> it's ok. I found that the constructor of nef-polyhedra accepts only
> standard Polyhedron_3 objects without an extended items classifier. I
> wanted to use the extended items in order to have a convenient way to
> calculate and store normals for vertices, faces& halfedges as shown in one
> of the examples.
Could I see what is CItemEx?
> In principle I do not necessarily need nef-polyhedra if there is another
> convenient way to do intersections, differences and unions of Polyhedron_3
> objects. By definition all of my polyhedra should be closed. The only other
> two requirements that I have is that I have to test if a point is included
> in my polyhedron (and nef-polys provide a nice way to do this) and an
> intersection query for rays.
> So if there is a different way to achieve this without using nef-polys then
> I'll also be glad to give it a try.
You can use the AABB_tree for those tasks.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html
Sebastien.
> I'm completely new to CGAL so I'm grateful for any information!
> Cheers
> Chris
> From:
> [mailto:]
> (GeometryFactory)
> Sent: 14 February 2013 17:01
> To:
> Subject: Re: [cgal-discuss] Extended polyhedra& nef_polyhedra
> Do you have a minimal example showing the issue?
> Depending on what you need, you might be interested by the
> corefinement plugin in the Polyhedron demo that performs boolean
> operations on Polyhedra directly (select the two polyhedra in the A/B
> column). The constraint is that the intersection polylines between the
> polyhedra are closed (including the boundaries)
> Sebastien.
> On 02/14/2013 03:36 PM, Chris Theis wrote:
>> Hello,
>> I'm currently trying to implement a module which needs to perform
>> boolean operations on polyhedra.
>> In general I'm using a class which is derived from CGAL::Polyhedron_3
>> for managing my solids and for the boolean ops I would like to
>> convert the polyhedra to nef_polyhedra and then back.
>> If I do something like this:
>> CSGPolyhedron<Kernel, CGAL::Polyhedron_items_3> TestPoly;
>> then the compiler is happy. However, I have extended my polyhedron
>> items so my actual conversion would look like:
>> CSGPolyhedron<Kernel, CItemsEx> TestPoly;
>> CItemsEx is derived from CGAL::Polyhedron_items_3 and handles the
>> information for vertex& face normals. However, when I'm using my
>> extended items then the compiler starts complaining:
>> snc_structure.h(174): error C2903: 'Halffacet' : symbol is neither a
>> class template nor a function template ....and many more error
>> messages
>> I could trace this problem back to the use of the extended items. In
>> principle I would not need the extended functionality within the nef
>> polyhedra. But I don't know how to do the conversion of my extended
>> polyhedron to the nef_polyhedron. The available constructors do not
>> seem to work.
>> Is there any other way to do this? I'd greatly appreciate any hint in
>> this direction because I would really like to keep my extended items
>> for the polyhedra.
>> Thanks a lot
>> Chris
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Extended-polyhedra-nef-polyh
>> e dra-tp4656726.html Sent from the cgal-discuss mailing list archive
>> at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
