cgal-discuss - Re: [cgal-discuss] Extended polyhedra & nef_polyhedra
  • To:
  • Subject: Re: [cgal-discuss] Extended polyhedra & nef_polyhedra
  • Date: Fri, 15 Feb 2013 09:41:36 +0100
I'm sorry but I can' compile a minimal example as I don't have
all the classes you use. It will same my time if you provide me
a complete example that does not compile.
Note that even if it were compiling, all the attributes of the
Polyhedron_3 won't be transfered to the Nef_polyhedron_3.
If you want to try the experimental boolean operations on Polyhedra,
have a look at the file CGAL/corefinement_operations.h
The class Polyhedron_corefinement is the one you should look at.
There is some documentation in doxygen style that should be sufficient
to start. If you try it, some feedback is welcome.
Sebastien.
On 02/15/2013 08:53 AM, Chris Theis wrote:
Hello,
My CItemsEx is the following code below. It's actually based on one of the
provided examples. However, I found in one of the demos that there is a
function to calculate normals for polyhedra. If there is no other way then I
guess I can use this one and store all my other attributes in a wrapper class
which will then contain the actual geometry solid as a member.
struct CItemsEx : public CGAL::Polyhedron_items_3
// A redefined items class for the Polyhedron_3 with a refined vertex class
that contains a
// member for the normal vector and a refined facet with a normal vector
instead of the
// plane equation (this is an alternative solution instead of using
// Polyhedron_traits_with_normals_3).
// wrap vertex
template<class Refs, class Traits>
struct Vertex_wrapper
typedef typename Traits::Point_3 Point;
typedef typename Traits::Vector_3 Normal;
typedef CVertexEx<Refs,
CGAL::Tag_true,
Point,
Normal> Vertex;
// wrap face
struct Face_wrapper
typedef CFacetEx<Refs,
CGAL::Tag_true,
Point,
Normal> Face;
// wrap halfedge
struct Halfedge_wrapper
typedef CHalfeEdgeEx<Refs,
CGAL::Tag_true,
CGAL::Tag_true,
CGAL::Tag_true,
Normal> Halfedge;
Thanks a lot
Chris
Chris Theis
CERN/DGS-RP - European Organization for Nuclear Research
1211 Geneva 23, Switzerland
Phone: +41 22 767 8069 Office: 892-2A-015
e-mail:
www: http://www.cern.ch/theis
-----Original Message-----
[mailto:]
On Behalf Of Sebastien Loriot (GeometryFactory)
Sent: 15 February 2013 07:09
To:
Subject: Re: [cgal-discuss] Extended polyhedra& nef_polyhedra
On 02/14/2013 05:14 PM, Chris Theis wrote:
Hi Sebastien,
my problem actually starts when I do the following:
CGAL::Polyhedron_3<Kernel,CItemsEx> TestPoly; //
CItemsEx is derived from Polyhedron_items_3 and extends vertices, faces& halfedges
CGAL::Nef_polyhedron_3<Kernel> TestSolid( TestPoly );
as long as I use
CGAL::Polyhedron_3<Kernel, CGAL::Polyhedron_items_3> TestPoly;
it's ok. I found that the constructor of nef-polyhedra accepts only standard
Polyhedron_3 objects without an extended items classifier. I wanted to use the
extended items in order to have a convenient way to calculate and store normals
for vertices, faces& halfedges as shown in one of the examples.
Could I see what is CItemEx?
In principle I do not necessarily need nef-polyhedra if there is another
convenient way to do intersections, differences and unions of Polyhedron_3
objects. By definition all of my polyhedra should be closed. The only other
two requirements that I have is that I have to test if a point is included in
my polyhedron (and nef-polys provide a nice way to do this) and an
intersection query for rays.
So if there is a different way to achieve this without using nef-polys then
I'll also be glad to give it a try.
You can use the AABB_tree for those tasks.
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/AABB_tree/Chapter_main.html
Sebastien.
I'm completely new to CGAL so I'm grateful for any information!
Cheers
Chris
[mailto:]
(GeometryFactory)
Sent: 14 February 2013 17:01
To:
Do you have a minimal example showing the issue?
Depending on what you need, you might be interested by the
corefinement plugin in the Polyhedron demo that performs boolean
operations on Polyhedra directly (select the two polyhedra in the A/B
column). The constraint is that the intersection polylines between the
polyhedra are closed (including the boundaries)
Sebastien.
On 02/14/2013 03:36 PM, Chris Theis wrote:
Hello,
I'm currently trying to implement a module which needs to perform
boolean operations on polyhedra.
In general I'm using a class which is derived from CGAL::Polyhedron_3
for managing my solids and for the boolean ops I would like to
convert the polyhedra to nef_polyhedra and then back.
If I do something like this:
CSGPolyhedron<Kernel, CGAL::Polyhedron_items_3> TestPoly;
then the compiler is happy. However, I have extended my polyhedron
items so my actual conversion would look like:
CSGPolyhedron<Kernel, CItemsEx> TestPoly;
CItemsEx is derived from CGAL::Polyhedron_items_3 and handles the
information for vertex& face normals. However, when I'm using my
extended items then the compiler starts complaining:
snc_structure.h(174): error C2903: 'Halffacet' : symbol is neither a
class template nor a function template ....and many more error
messages
I could trace this problem back to the use of the extended items. In
principle I would not need the extended functionality within the nef
polyhedra. But I don't know how to do the conversion of my extended
polyhedron to the nef_polyhedron. The available constructors do not
seem to work.
Is there any other way to do this? I'd greatly appreciate any hint in
this direction because I would really like to keep my extended items
for the polyhedra.
Thanks a lot
Chris
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Extended-polyhedra-nef-polyh
e dra-tp4656726.html Sent from the cgal-discuss mailing list archive
at Nabble.com.
